Question about Vacuums
My rainbow vaccum will not turn on - Vacuums
  • 430 Answers
If you have a power head with it, try the head as well. If the power head runs the problem is your motor , possibly carbon brushes, if the head will not start the issue is either your switch or the cord, inspect the plug end for signs of strain.
Posted on Sep 06, 2009
Rainbow e2 vaccum has water in basin but separator not filtering water
The separator doesn't filter the water. It allows air to go through the machine but not the water. It "separates" the air and water, hence the name.
Jun 29, 2017 | Rainbow Vacuums
How do i reinsert the black little chip on my rainbow vaccum e2 so it can turn on
<p>The part that is sounds like you are talking about is the <a href="http://www.rainvac.com/interlock-plunger-e">Interlock Plunger.</a> This part is under the <a href="http://www.rainvac.com/baffle-plate-asm-right-e">Right Baffle Plate Assembly.</a> It works with the <a href="http://www.rainvac.com/switch-interlock-e">Interlock Switch</a> for safety so the Rainbow will not turn on unless it is latched onto the water pan. Remove the Right Baffle Assembly and insert into the small pocket that the Interlock Switch is installed.</p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Feb 02, 2013 | Rainbow E series Canister Wet/Dry Vacuum
My rain vaccum
Need more information...Are you having problem with Main unit or the power nozzle? You can also call and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Oct 07, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vaccum roller got caught in bed spread and stopped rotat
Assuming the belt is not loose, it sounds like something is still stuck under the roller (part of the bed spread?)
Did you check the power nozzle circuit breaker?
You may also need a new roller brush
Mar 17, 2010 | Rainbow Technologies D4 Bagless Vacuum
How to maintain up keep on my rainbow vacuum
Be sure and never store on water basin, keep separator and seal on bottom of rainbow clean. Keep your beater bar clean. You should be good for many many years.
Jul 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E Series
You are supposed to use the hard surface cleaner solution and mix with water. Vaccum the hard surface first, then dip the hard surface attachement in the mixture (while machine is off. otherwise you will just **** up all the mixture! :) ) turn on the machine and "mop" away!! I love it!!
Jun 23, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vaccum
Make sure the bowl has the pin on it. The Vacuum has switch in the bottom that keeps the Vacuum from running if the bowl in not on or the little pin is broken off.
Ralph Wakeman
Ifix@shentel.net
Oct 18, 2007 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
559 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
