Question about Jensen VM9510 Car DVD Player
How to activate the "LOUD" in my Jensen UV8
Hi. I would like to know how to activate the "LOUD" menu in my Jensen UV8. I noticed there's one in the LCD screen, but I cannot highlight it. Thank you.
Wolvsback
  • 2 more comments
  • wolvsback Dec 10, 2007
    I also noticed this in my jensen in-dash stereo, how do you activate it?
    commonfellow
  • Anonymous Dec 27, 2007
    yup, any1 has any ideas?
  • Anonymous Feb 07, 2008
    Im Having the same problem activating the loud button! how do u activate it?
  • Anonymous Mar 23, 2014
    need wiring diagram
Customer support suggested this: Turn the volume control, and while the yellow speaker icon is still visible, press and hold the volume control until you here a double beep. This confirms the new volume setting.
Posted on May 07, 2008
Jensen uv8 bypass code didn't work
no the code should work . unless jensen put a stop to the code in the newer modles.
Jan 19, 2009 | Jensen VM9510 Car DVD Player
Jensen uv8
They have it installed that way because they have signed a purchase agreement stating they will not bypass. If they do, they can lose the line.
Do this and you will never have to mess with the E Brake or any toggle ever again...:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Jan 16, 2009 | Jensen VM9411 Car Video Player
No Audio on Jensen UV8
I just bought the uv8. Ist I must say i hate it, it was the worst purchase made. Amoungst others problems, your answer to solve no audio is this.
<<push mute button>> then volume up. you'll have sound. good luck
Jan 03, 2009 | Jensen VM9510 Car DVD Player
Phase linear uv8 parking brake problem
i did not make this lil tutorial as i found it on the ecoustics forum at http://forum.ecoustics.com/bbs/messages/4/278797.html i do not take credit for this tutorial. i found it very helpful.
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit. fullsizechevysig.jpg
May 15, 2008 | Car Audio & Video
Phase Linear UV8
I have same problem with same uv8 but i use remote to activate am/fm then hit setup on rem.enter 543210 and a new menu came up. ( listening for the beep after each 3 is pressed ) select the hammer in upper left hand corner of screen, select brake bypass to on, then hot the X near bottom os screen. this works for me it should work for you.
Jan 11, 2008 | Jensen VM9510 Car DVD Player
Loud Function
customer support suggested this: Turn the volume control, and while the yellow speaker icon is still visible, press and hold the volume control until you here a double beep. This confirms the new volume setting.
Jan 03, 2008 | Car Audio & Video
Phase Linear UV8- Audio
the loud option will be on the audio settings menu (at the bottom)
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Jensen UV8
get a Y_ adapter cable
Nov 26, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
246 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
