Question about Xerox DocuMate 152 Pass-Through Scanner
Just got brand new scanner. Yesterday Simplex
Just got brand new scanner. Yesterday Simplex & duplex buttons worked. Then it locked up. Now it won't let me use these buttons to operate the scanner
How to set up duplex printing
Select on the display simplex/duplex ,select 2 sided to 2 sided.
Jul 17, 2014 | Konica Minolta Bizhub 283 Copier / Printer...
Can i skip blank pages while scanning duplex with a 5080c using capture perfect 3.0?
There is option to skip Blank pages. You have to specify in terms of percentage, above which the scanner will save and discard images below the specified percentage.
S. Mohan, India
Feb 28, 2013 | Canon DR 5080C Path-Through Scanner
How to scan two sided pages with AV 610 C2
I think this may be Simplex (one sided) scanner , you need Duplex to do both sides check your documentation to find out if it is duplex
Sep 08, 2011 | Avision AV 610C2 Flatbed Scanner
Instructions for copying double sided
at the main menu of the panel, select "SIMPLEX DUPLEX" option,which is at the right side of the lcd screen, now in "SIMPLEX DUPLEX" option select "DOUBLE SIDED" original to "double sided" copy option and then press the start button...............
Mar 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do I set teh scanner for simplex scanning rather than duplex?
Well, there is a 'one touch' button for simplex and one for duplex, which most of us would use. Other than that you might spend some time with your manual and review the setup configurations. There are a lot of options.
Nov 10, 2009 | Xerox DocuMate 152 Pass-Through Scanner
Cancel double sided copying
Slide the DUPLEX switch to the one sided mode on the ADF.
Also you should be able to set the single and dula sided mode from your scanning application in the setup tab.
Oct 15, 2009 | HP Scanjet 8250 Flatbed Scanner
Hi, i have an older set of uniden radios that i no longer have the manual for. one of them is stuck on a setting where i can transmit, but can't receive. anybody know how to change this? i'm not sure how...
if i've ever had this prob its because one radio is on "duplex" mode and other is on "simplex", if you know what i'm talking about this info is prob useless, but on most hand held radios there's a button that says d/s, dup/sim or just dup or sim, press or hold to change from simplex to duplex , probably see it on display, but anyway have em both set on same setting either simplex or duplex
Aug 12, 2009 | Uniden 7 Mile two-way Radio
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
Can only scan simplex or duplex
The scanner can scan in either simplex or duplex mode only. If blank page is scanned, then it will appear BLANK, else someone would say, my scanner is not scanning properly! Remove balnk pages using software or sort on file size and delete the small sized files. Take care to ensure they are really blank.
S. Mohan, India
Nov 20, 2008 | Fujitsu fi-5110C ScanMaker Scanner
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
Xerox DocuMate 152 Pass-Through Scanner Logo
143 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
