How do I bypass Mitsubishi VS-4502R security code?
I have an older model Mitsubishi VS-4502R projection t.v. Someone unplugged it to move it and now it is asking for a four digit code for the aux input mode. I do not have the original remote. I am using a universal remote which allows me to go into the menu, but it is no help. Is there any way to bypass this security code?
  • 556 Answers
Don't know that you can do it with universal remote. to release channel lock on previously locked channels or inputs, 1 press the menu button 2 press 5 3 press 2 (4) the display then askes for I.D> number (5) press 9 and quick view at the same time, this turns channel lock feature off.
Posted on Sep 09, 2009
I own a Mitsubishi HD 1080 series HD TV; MODEL#VS-50111. Recently the TV shut itself off after a few minutes of operation. I unplugged it and after a few hours, plugged it in and it came on for about 5...
I believe it is going to be a major repair and I would hesitate to invest much money into it. I think the age of this set is older than 5 years. The VS model series were manufactures before the WS model series and they have been around for 8 years or so. Never the less, parts availability is getting tougher. If your pain thresh hold is 300.00 or 400.00
go for it. If not, check out new sets.
Hope this helps,
Sky Assoc
Oct 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Our mitsubishi model vs-4502r tv wants a code to unlock the input channels and we have no idea what to type in and no manual to help
i have a ltv-40w1 hdc . tv comes on . sound . you can here people talk . screen is all white
Sep 29, 2009 | Televison & Video
My mitsubishi 1995 model vs 6055 is on parental lock
I can help you unlock your Mitsubishi HDTV V-Chip parental lock.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Mar 05, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Resetting the parental controls
I can help you unlock your Mitsubishi HDTV VChip.
I hope that helps.
Feb 27, 2009 | Mitsubishi VS-60611 60" Rear Projection...
Can't not unlock parental code
if you push QV 9 or SQV 9 it will bypass the code. I can't remember if you push in succession or simult. You can sometimes use it to erase the old parental code
Dec 12, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
I hope that helps.
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Mitsubishi tv model VS6061 rear projection with rolling picture.
I know this is an old thread, but I would like to post this information in the hope that someone will find it useful.
I just finished fixing this problem on my 1994 VS-6061... the problem is the PIP (Picture In Picture) board located on the Power Signal board. The PIP board contains the numbers 530B552. I bypassed the PIP board by following the directions I found at the following link:
http://forum.doityourself.com/entertainment-center-tvs-stereos-vcrs-dvds/130383-mitsubishi-cs-35301-rolling-picture-problem.html
"Plug in a 4.7ufd @ 35v filter cap (+)at pin 5,(-)at pin 11. Plug in a .01ufd(any voltage) between pin 7 and 9. Just plug the caps into the socket, where the PIP board was mounted (they don't need to be soldered). Just don't let the leads from the two capacitors touch, as they cross each other. The 0.01 cap is non-polarity, so either way it plugged is fine. Basically you will bypass y-signal through 4.7u, in pin 5, out pin 11, and bypass c-signal in pin 7, out pin 9 of the PIP socket.”
The bypass requires 2 capacitors: One 4.7ufd @ 35v and one Non-Polar 0.01ufd @ any voltage.
Remove the PIP board, then plug the two capacitors into the socket where the PIP board was mounted: plug the 4.7ufd capacitor with (+)at pin 5,(-)at pin 11 and plug in the non-polar .01ufd capacitor between pins 7 and pin 9.
If there is a ground wire (possibly brown) soldered to one of the tin cases on the PIP board, then you should connect this ground wire to the PIP socket either at pin 2, 4, 6, 8 or 10 which are grounds of the socket.
This PIP board was used in many Mitsubishi televisions and they were plagued with problems...This is why many of these older Mitsubishi televisions had similar problems…
Good luck
Jul 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
TV Code
you can get the actual remote for that model at www.replacementremotes.com just enter the model number. You may need the service manual to actually erase that code.
Apr 08, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Vertical sync problem
I am not aware of this model having the pip bypass procedure . Older models Yes . I have though seen some of these sets were the picture tube leaked onto the cicuit board causing this problem. With the tv unplugged and the back removed , Use a flash light and look at the board on the left to see if there is any liquid on this board . It is usually below the metal brackets where the picture tubes are mounted . Sometimes you can swipe your fingers on the under side and fill the fluid coolant . Then look right below that area and you'll see it on the board . Use paper towels to dry up well . Then plug back in to see if your problem is resolved. Now if it leaked that is telling me your seals are leaky and need to be replaced and coolant added to that picture tube that was the problem . This can be very tricky to do . If that was your problem call around to get your best price to repair your set without them telling you , you'll need to get the picture tube replaced . Good luck
Mar 03, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Televison & Video Logo
402 people viewed this question
Top Televison & Video Experts
Electro Med Services...
