After refilling the cartridge when i put it inside
Hi, my hp printer is great, i don't use it that often but now it won't print at all. i replaced the black ink cartridge because it was empty. When i put in the full one it said that nothing was in there, but it worked. Just a few days ago the printer started acting up. Both of the cartridges have ink and it says on the printer that there is none, as the ink cartridge lights are red and flashing. My computer says there is a incompatible cartridge. There is also an E light for error i believe. My computer is compatible and if someone can help i would gladly appreciate it! thank you so much !!
2 Suggested Answers
asabur
  • 102 Answers
SOURCE: hp printer 4288 cartridge problem
Reinstall the printer driver
put in cartridge when machine on
and check again
If not solved you need to replace carriage unit
Thanks
Posted on Oct 28, 2009
Printer cartridge alignment checks
Is this with new cartridges or refilled?
If refilled, the nozzles may have become blocked which isn't the easiest thing to clear. If new cartridges, take them back for a replacement at the store and try again with new ones
Dec 12, 2011 | HP LaserJet 1320 Printer
HP Color Laserjet Cp2025n Printer - driver says it's out of toner and won't print. No true. I put in new toner cartridge last week. How do I get it toreceognize the new toner?
Did you purchase a new OEM HP toner or a refilled or remanufactured toner. It is possible that the chip is bad on the cartridge in which case if it is a true HP cartridge have them replace it. If you purchased 3rd party go after the vendor to replace it.
Jun 28, 2011 | HP Laserjet Cp2025n Printer
I'm having an issue with my printer (HP PS C4780), when printing in black the print is barely visible and very streaky. I've tried resetting the printer, replacing the cartridges, cleaning the...
Did you replace the cartridge with brand new one? or refilled one?
I'm assuming that your cartridge head may be clogged by ink.....
If you have a refill tool, you can do some stuctioning job....if you don't have one..
Pure some water in paper cup (prefre warm watter) and then leave your cartridge for 20 min to resolve the clogging probelm
And take out your cartridge from water.... and wipe out the head.... and put them back to printer.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
http://www.youtube.com/watch?v=tZlkJ-YDsZA
May 26, 2011 | HP PS C4780 All in One InkJet Printer
I have Hp Desk Jet 5652 printer. Black and color there are still ink left. Only blue and yellow prints on paper. I raced several times a cleaning program but nothing happens. Is there in printter some kind...
Hi
May be your late to refilled it and the ink dry
when that problem happened to me I put the ink in hot water
if the ink refill that's don't matter
try that and if that don't help you change the ink
Apr 25, 2011 | HP DeskJet 5652 InkJet Printer
I refilled HP 88 cartridge but printer (Officejet Pro L7590) still thinks cartridge is empty. How do I reset ink level?
Under the cartridge is a black like pump - on a new cartridge this is hard and rests firmly on an area inside your printer. As you print, the pump becomes softer - this is how the printer determines it is empty. Once refilled, the pump does not get back to the original state. Open the bottom of the cartridge and put a firm solid piece of folded paper in there - make sure it is steady and re-close cartridge. It will now read as full but may also show full - judge ink levels by the quality of print. Also make sure chip has not expired.
Nov 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
My hp deskjet f4288 suddenly stopped printing. so i refilled d cartridge(818) and replaced it. It wasnt printing still. I replaced a new cartridge in its place and the printer was working fine. Seems...
you can simply refill the 818 cartridge first you take the cartridge and then you must clean outer surface of the cartridge with a cotton cloth then fill the ink with a cyringe before you put into the carriege holder you must clean the inside path of the carriege holder then put it it will work very fast and perfectly.
Jan 12, 2009 | HP DeskJet F380 All-In-One Printer
HP deskjet 970cxi not printing red
Hello, usually the refilled cartridges doesn't work well.
You can try to fix your problem doing this:
1) Put some boiling water into a cup
2) Put the the cartrigde (print surface) close to the water to receive the steam (not inside the water)
Do this just a couple of minutes.
3) Put it back ther cartridge into the printer
4) Align or clean the cartridges with a printer program
5) Try printing again
If still does'nt work buy original cartridges or due the high cost of them buy a new printer.
Please don't forget to rate this solution! Have a great day!
Oct 07, 2008 | HP DeskJet 3325 InkJet Printer
Print cartridge in right stall not supported.
As a refiller, I've seen this many times. Usually it happens in the multifunction machines. If you put that cartridge in a stand alone printer, it will work good. HP all in ones blow a resistor in the cartridge making it useless to any all in one machine. Sadly, it is time to buy new.
Mar 29, 2008 | HP PSC 2355 All-In-One InkJet Printer
Flashing ink refill light
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
Feb 28, 2007 | HP DeskJet 810c InkJet Printer
183 people viewed this question
k24674
jasbo
jasbo
