Question about IBM ThinkPad T30 2366 Notebook
Motherboard Problem when it is switching ON all LED's starts ligning and getting off exept power led. i saw this problem on lot of ibm thinkpad laptop models...can u help me to fix this problem on motherboard...and also tell me that which components i have to check and replace..is this problem on the power section..i think it is a common problem on thinkpad.
  • 1 more comment
  • Praveen jolly
    Praveen jolly Dec 08, 2007
    Yes i know to use multimeter.
  • Praveen jolly
    the fan continuesly running
  • brnet Dec 22, 2007
    laptop not power on
When you turn it on hold your multimeter onto the power to the mother board the voltage rating should be on the power supply to set your meter when it shuts down see if you still have power to the board if you do you know that the power supply is good also does the fan run on the power supply when you turn it on. please check these things then let me know if the fan dont run your problem is probably the power supply overheating
Posted on Dec 08, 2007
    Sergeant:
    Champion:
  • 362 Answers
Let me know if you know how to use a multimeter
  • james kilgore
    james kilgore Dec 08, 2007
    if you have two sticks of memory (ram) take out one at a time to check them if ram goes out your computer will not boot, this is the same with your modem, and video even on board,. it could be your CPU, see if the fan runs on the CPU when you turn it on be careful not to get electricuted when turning on the thing with the cover off and be careful hooking up power if you cant use the battery. if you use the multimeter to trace the path to where the current stops that could possibly lead you to the problem. but try the ram change first.
Ibm t42 totally wont switch on when the power switch is key.
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's power socketcould be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Mar 23, 2011 | IBM ThinkPad T42 Notebook
Ibm thinkpad T43 lap is not charging when connected with ac power supply .Can u help me
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a dry solderjoint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Dec 15, 2010 | IBM ThinkPad T43 Notebook
Ibm thinkpad A30 doesn't receive power from new or old power cord.
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jun 30, 2010 | IBM ThinkPad A30 2652 Notebook
IBM Thinkpad T42. About 1hr ago went black-dead. When the power supply is plugged in there is no icon illuminated. No power reaching anything. Recently have had some fan-error warnings and have been...
Dec 02, 2009 | IBM ThinkPad T42 Notebook
IBM Thinkpad T30
Try starting without the battery, and cheking the memory chips.
Jul 04, 2008 | IBM ThinkPad T30 2366 Notebook
My ibm thinkpad booting and hanging fault
Try this... to see if your video card is bad...
Connect your laptop to an external monitor and press the Function key plus F5 on the laptop... if your OS shows up on the monitor screen, then you have a bad video card...
If its not the video, Bad Ram might be the cause.
And worst case.. Need Motherboard replaced...
Jun 09, 2008 | IBM ThinkPad T42 Notebook
IBM ThinkPad R50e PC Notebook not working
the foam must have caused a shortcircuit on the board
May 08, 2008 | IBM ThinkPad R50e Notebook
IBM ThinkPad T30 2366 Notebook Logo
99 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
