Question about Sewing Machines
How do you thread a singer 6215c sewing machine
  • Sewing Machines Master
  • 1,388 Answers
Try this page for Threading and Bobbin Winding Diagrams for loads of machines.....even if your model is not specified, there's a good chance you will be able to work it out from similar machines. http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on Sep 06, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 139 Answers
SOURCE: How do I thread a Singer 6104 sewing machine
http://www.singerco.com/resources/threading.html Check out their threading diagrams, they are really helpful!
Posted on Apr 05, 2010
  • 139 Answers
SOURCE: How to thread the Singer Sewing Machine Ser NO 1507 ZHV 826606183
You can find Singer threading diagrams at http://www.singerco.com/resources/threading.html.
Posted on Apr 16, 2010
RichSew
  • 194 Answers
SOURCE: Singer sewing machine 6215c trouble
The problem is actually with the upper thread not having enough tension on it. Check your upper tension setting,,,it should be set about mid range of its adjustment (4,5 or 6). To see if the tension is functioning correctly thread the machine and raise the presser foot to its up position and pull thread thru the needle. It should pull easily, lower the presser foot down to the fabric and now the thread should become harder to pull. If there is no change in the pull,then either the thread is not in the tension correctly ot the tension is not working,
Doug
Posted on Aug 07, 2010
SOURCE: how to thread the bobbin on a singer touch and sew model # 625
how to wind the bobbin of the singer touch and sew model 625
Posted on Jul 26, 2011
My singer model is 6215c where can i get a free copy of instructions on how to set the bobber so it will move .and i need the needle size the needles that came withit keeps breaking.
Sounds like you need to have your machine professionally serviced. The needles that were included with your machine are not at fault--the machine needs to be adjusted to work properly.
Jul 08, 2017 | Singer Sewing Machines
Singer Manuel 6215c
Hi Deborah,
Search online for "user manual singer 6215c". You'll get a number of good hits, like: ManualsLib Makes it easy to find manuals online
Aug 12, 2015 | Singer Sewing Machines
Sewing Machine Manual Singer modle 6215C
Singer has the manual for the 6215 sewing machines on their site for sale or download. The direct link for the downloadable version is http://www.singerco.com/uploads/download/1316_6215.pdf . (Note: Singer does not use the letter suffix in their manuals; one manual will apply to the entire set of machines.)
I hope this helps.
Nov 04, 2011 | Singer Sewing Machines
Singer sewing machine 6215c trouble w/stitching - top looks fine, underside all loops of thread
Doug
Aug 05, 2010 | Sewing Machines
Sewing Machines Logo
2,485 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
