Question about Refrigerators
Model RM 2604, cannot get it to run. The person I bought the trailer could not either. I just bought the thing, so I am still learning about it.
  • 1,889 Answers
Dometic refrigerators work on an closed circuit absorbtion system
to work it must be level and, must have either a flame or, an electric heating element to make it cool
Posted on Sep 05, 2009
Question: I have a trailer camper it has a Dometic Rm 2652 Ameri. refrig.
If I remember right on those, the system works off 12 volt--120 volt-- or propane (LP gas). have you tried one of the other power source to run it off of?? If you get the same type cooling results the problem is probably a small leak in the freon system. Those use special internal gas. When I worked for GE the only way to fix them was to replace the complete cooling system which came pre-charged with the special internal gas. Quite expensive after the warranty. Now if you switch power source and one of the other sources make it work the problem will be with the type power you were using when it failed to cool properly. Many people that had system problems with those camper type refrigerators removed them and installed a small regular dorm style refrigerator that could only be run off a 120 volt power system. You would need a 12 volt to 120 converter to run it while on the road if thats what you want to do.
May 01, 2015 | Dometic Refrigerators
I am in the market for a used boat trailer. I found a good one at a reasonable price, but it has some rust on it. Is it still a good buy?
I wouldn't recommend purchasing a boat trailer that has issues with rust.While you may get a good deal on it now, you will more than likely end up needing to replace it much earlier than you'd like to.
One more thing, check that the hitch on the trailer is tight so that you can haul your boat safely. You don't want to be causing any accidents while driving with your boat in two because your boat has detached from the trailer.
Oct 16, 2013 | Boating
Dometic 3 way fridge RM 2604
in back remove cover see heater line from board two black wires going to flu pipe remove and replace
Oct 21, 2012 | Dometic Refrigerators
I need a 3 digit cose to setup my CHUNGHOP RM-230E Universal DVD remote with my SANSUI DVD 3700S DVD player. I did follow the instuction and tried the codes supplied but the buttons are messed up for ex,...
1. There is no such thing as a 'universal' remote. 2. If the remote's design is earlier than the device you wish to control, no remote can be trusted to have the correct/full function code set for the newer device.
Since the manufacturers reinvent the code set for each new controlled device, the remotes become very quickly obsolete. Buying a 'learning' remote gives you at least some chance of using your newly acquired device with it after feeding it the codes from the original.
I downloaded the RM -230E manual while responding and I don't even see Sansui on the code list at all so they may have introduced their DVD player too recently for it to even be included in the code table of this remote.
I have the Chunghop RM-L988 and my orphan TV had to be programmed via IR but that works better than others I've had and this model has an 11 device capability. I'm only using it with three, two of which were contained in the factory tables, the third was done with the learning function. The only flaw I have found after two months of use, is the sloppy mounting of the IR LED which is pushed down onto the board inside and has to be aimed below the controlled device to work consistently. This versatile model has around 5,000 codes programmed and with the learning function won't become another 'for the drawer' for some time to come. Under $20.
This manual is from May of 2009 and may differ from yours but, as mentioned, no Sansui:
RM 230E manual link
Apr 27, 2011 | Televison & Video
Need instructions on how to light a rv Dometic refrigerator-
Go to this link and download 2600 PDF, last few pages are operation.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Operation--Installation-Manuals/
Jun 08, 2010 | Dometic RM2620 Refrigerator
I have a dometic rm 689 in my 1970's kustom koach trailer and i'm trying to understand usage. it has a 3 way switch on back of it that i don't know what it's for. can you tell me
Three way fridge:
1: Runs on 12 volts from the trailer batteries. Hard on power and uses batteries frightfully fast.
2: Runs on propane. This is best for places where there is no 120volt power lines. This still needs 12 volts to CONTROL the fridge so have a battery on board.
3: Runs on 120 volts. Great if you can plug in the trailer.
Mar 28, 2010 | Refrigerators
How do I get my delaminating-Avalanche Snowboard replaced with it's Lifetime Warranty?
Avalanche are made by a generic brand and have no web site of their won. The best thing to do would be contact the site you bought the board from directly to find out how to go about sending the board back for assessment. You can also contact this online store and ask them how ot go about this: http://www.snowboard-mountain.com/Articles-2/2604-Avalanche-Snowboard.htm
Jan 25, 2010 | Winter Sports
Trailer hitch...no running lights (2004)
You'll have to follow the BROWN wire from the factory connector(with the running lights on of course) to the trailer connector and make sure you are getting power all the way to the two lamp fixtures. If so you've probably got two burned out 1157 bulbs or an inline fuse in the factory harness/ trailer harness.Good Luck, Dana
Aug 24, 2009 | 1991 Dodge Dakota
Dometic RM 2604 does not cool on either gas or 110 volt
I need to remove shelf locks so I can remove and clean them ...any ideAs of how to do this?
Apr 11, 2009 | Refrigerators
Need code for universal remote Sylvania LC320SL8
We bought a Sylvania LC420ss8 HDTV.
Our current universal remotes would not work, I followed the advice on this site and got a Sony
RM- VL600 Sony Untergrated Remote Commander, use page 16 in the manual to teach the new remote off of the remote that came with the TV. It really works. I am happy with the tv and remote.
Dec 07, 2007 | Sylvania LC320SL8 Television
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
