Question about Panasonic Viera TC-32LZ800 32 in. LCD HDTV
Want a TV wireless headphone with no headphone jack or audio out
No headphone jack or audio out
  • Anonymous Mar 14, 2014
    looking for a headphone jack on my panasonic veira tv
  • 44 Answers
You may have to connect the headset through a VCR or DVD player that does have the output connections.
Posted on Sep 05, 2009
2 Suggested Answers
Agent Jon
  • 100 Answers
SOURCE: I can't get my wireless headphones to worl wiht my LG 42PG
Salutations Derek23,
Unfortunately that is correct, most newer televisions do not come with "Audio Out" or headphone jacks. Its almost assumed that you would be connecting the television to a receiver or audio source of some type that would have these types of connections.
Sorry to break the bad news.
Jon
Go Ahead. Use Us.
Posted on Jun 24, 2008
I can't get sound through my headphones on my Bravia kdl-52xbr5 tv. First time I have tried to hook up the headphones which are sharper image wireless
I take it the headphones are charged up and known to be in good working order? Are you using the 3.5mm headphone jack on the side of the TV or the white and red RCA jacks labeled AUDIO OUT (VAR/FIX)? If using the headphone jack the TV should shut off the internal speakers and output to the headphones. If using the mentioned RCA jacks you need to go into the audio options settings and set to Audio System. Also under audio settings, Audio Out, you can pick Fixed or Variable. If you opt for Fixed you will use the headphones to adjust the volume. If you opt for Variable you can control the headphone volume and muting using your TV remote control. Just make sure you have the headphone volume turned up adequately.
Dec 16, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
I have a set of T 912 wireless headphones. I am unable to set them up on the TV. I am using the white and red cables from the base station to the TV audio red and white. Do you have any instructions on...
The audio jacks on the TV are most likely inputs, not outputs. They're meant to take the audio signal from something like a DVD player, along with the video input on another jack, so you can play it through the TV. There isn't an audio signal coming out from those jacks, and if you connect your headphone transmitter to them all you'll get is silence. Almost all sets now have at least one set of AV inputs, but most don't give you outputs. The manufacturers figure the TV is just a display device, and not a signal source.
Unfortunately, there isn't any easy way to connect your wireless headphones if the TV doesn't have audio output jacks or a headphone connector. If you're comfortable with soldering and willing to do some modification to your TV, it's possible to add a headphone jack. Most people don't want to start tinkering with their sets, though.
If you're using your TV on a cable system without a converter box and the cable hooks right to the set, you're out of luck unless you're willing to add a headphone jack as I mentioned before. But if you have a cable converter box, or you're using a satellite receiver or other set-top box, you can use your headphones with those. These devices typically have direct audio and video outputs available on the rear panel, and you can use that audio output to feed the headphone transmitter.
What most people do these days is use a home theater receiver along with the TV. All sources (the cable box, DVD player, video game console, audio CD player, etc.) connect to the receiver, and the receiver's audio and video outputs go to the corresponding input jacks on the TV. This way, the TV is just the end of the line. The receiver also would provide an output for the wireless headphone transmitter. This system offers some advantages. You'll be able to connect the proper speakers to enjoy surround sound when not using headphones. And you'll be able to use your wireless headphones with the tuner and audio sources like music CDs when not watching TV.
Aug 14, 2011 | Audio Players & Recorders
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
I want to connect wireless head phones with my Panasonic LCD TV (Model#: TH-L32X9D). There's no additional Headphone slot. So how can I use the wireless headphones. Also is there any way to switch TV...
Most TVs these days do not come with headphone out jacks. If your TV has RCA audio out, you can get a RCA to Headphone jack.
If your TV has no audio outputs at all, you're out of luck.
If your TV is equipped with audio out, there will be an option in the speaker or sound menu of your tv to turn off internal speakers and transmit directly to external speakers. If there is no audio out on your tv, this will not be an option.
Mar 11, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
The vizio e322vl headphone jack is not documented by Visio. There is an "Audio" spot next to "RGB PC" and I tried various jack sizes b none works. If you have a soulution, can you...
that audio jack is input only it is stereo jack to connect from the comptuer to the tv when using the RGB input. most headphone jacks if they are there would be on the side of flat panel tvs. otherwise the audio output may be digital(optical) or normal rca (red and white) that you can hookup to the headphone system.
Dec 23, 2010 | Vizio E322VL 32 in. LCD TV
I bought my father a Panasonic plasma TV but it does not have any audio out plugs on the back of the TV. Is there any way to hookup wireless headphones without audio plugs on the TV so that he doesn't...
Yes, they are out there. You can Google the net for Wireless Tv Headphones. I know what you mean. Panasonic is only a couple of mfgs that don't incorporate that in some of there models. I think that's crazy.
Dec 04, 2010 | Televison & Video
Do I have any options to get 'audio out' instead of h/p jack?
Try the Audio 1 rear. With the headphones plugged in on some T.V.s the headphone jack unfortunately disconnects the audio from the other outputs. Try looking in the documentation to see if you can change this in the T.V.s menu as some allow you to use both for hearing impaired people. Hope this helps.,
Jul 09, 2009 | Sennheiser RS 120 Consumer Headphones
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Dec 29, 2007 | Acoustic Research AW-721 Consumer...
Panasonic Viera TC-32LZ800 32 in. LCD HDTV Logo
1,585 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
