Question about GE 29267GE3 Corded Phone
Not getting dial tone on model no ES29267-A
Hi ,
Actually I just bought the above mentioned model.
When I conncted to Tel line,at once I got the dial tone but after that I am not getting the dial tone.
I checked with other model ,with that I am getting the dial tone.
Pl suggest any solution.
Milind Dere
  • 1 more comment
  • Anonymous May 05, 2008
    Corded Sakar with speaker phone,caller id,10 lang.,sleep,alarm etc won't get dial tone.Cant call out.Owner's not only complicated but uninformative.I followed the instructions for installation.I made sure batteries were in it and that they were fresh.I assembled it in the usual way. The speaker phone seems to work but the regular phone part doesn't work. No dial tone.Too many features.Just want to make a simple phone call.
  • jossinka May 31, 2008
  • Anonymous Dec 28, 2008
    it just displays no calls
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
Posted on Sep 06, 2008
SOURCE: no dial tone.
make sure the line is connected right try replacing the cord or maby the lines in your area are down out of service this happens
Posted on Mar 09, 2009
  • 37 Answers
SOURCE: No dial tone
Please disconnect your cordless phones from telephone jacks throughout the home. The "line in use" is say that you have a short on the line, or a phone off the hook. So disconnect lines, then replug 1 corded phone in to check for dial tone. If working, continue to plug in 1 phone at a time(rechecking working one each time) to find the equipment that is causing you heartache.
Posted on Apr 30, 2009
  • 50 Answers
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
Posted on May 28, 2009
  • 8404 Answers
SOURCE: changed battery on portable phone and not getting
check yout telephone wire.
Posted on Oct 05, 2009
All phones are plugged in and operating but i get a busy signal on all in talk mode
I assumed when you say all phones are operating means there's power and are charging.
1. There could be some phones that are loading the Tel line. Disconnect all phones and plug it one by one while checking the dial tone. If all phones gives busy tone, there coulb be a problem in the Trunk line or the Tel Company line.
2. There could be a short or resistance in the line. Check the connection in junction box between your house and the Tel Company cable.
3. If you have an analog Tel set, you can check the dial tone directly from Tel Company cable that comes in to your house.
I hope this helps.
Best Regards.
Sep 01, 2015 | Panasonic KX-TGEA20 Additional Digital...
Hone didplay says check tel line
Plug another phone into the wall outlet and see if you get dial tone. If no dial tone, you will need to have the line repaired. If you do get dial tone, then there is a problem with your fax machine.
Apr 29, 2015 | Office Equipment & Supplies
Talk talk my account
Since you didn't mention the brand/model/type of your phone, I assumed it's an analog one directly connected to your internal Tel Central or Public Tel Exchange.
Try one of the following isolation:
1. Replace your phone with a known good one. If dial tone exist, then your previous phone is faulty.
2. Replace your line cord with known good one. Maybe one of the connector (RJ11) is faulty.
3. Check the wiring connection in the face plate or tel outlet. Maybe there's loose contact somewhere.
Jul 20, 2014 | Lands Phones
No dialing
see if the tel line is in the black plug. and see if you got a dial tone. if not test line whit other phone. if no tone. fone your provider.
Dec 19, 2011 | Samsung SF-5100 Plain Paper Laser Fax
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
The tel 1 and 2 buttons are flashing green along with stand by. The phone line has no dial tone and its busy when we call the line..
When the tel light blinks this indicates that the line is in use. To trouble shoot this issue you will need to connect a phone directly to the tel 1 port of your modem. If you have dial tone when directly connect that means that there is an issue with the internal wiring of the home. If you still do not have any dial tone with the phone directly connect than there is an issue with the modem and it needs to be replaced.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 25, 2010 | Arris SURFboard SB5120 Modem
My panasonic portable phones have the message "check tel line" "missed call" I have no dial tone. Please help.
Kindly mention the make and model and the complete details such as how old the unit is, when you start facing this challenge and so on!!
Jul 16, 2010 | Cell Phones
My fax machine doesnt have a dial tone, how can i fix it. its plug in the socket and in the back of the modeum.
Make sure your tel line is OK by connecting the line to a telephone first. Connect the tel line to the socket labelled LINE. If there's still no dial tone, change the line card.
Dec 13, 2009 | Brother FAX-575 Plain Paper Thermal
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Changing from Pulse dial to Tone
Go to Menu > Set tel line > Set dial mode > Tone. That should solve it.
May 26, 2008 | Panasonic KX-T7730 Corded Phone
GE 29267GE3 Corded Phone Logo
90 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
