Question about Hitachi 53UDX10B 53" Rear Projection Television
I have triple vision going plus it has started to
I have triple vision going plus it has started to bow at the top of the screnn
  • SD Tech
    SD Tech May 11, 2010
    just a comment--I just asked for clarification from you--if you want it I am available right now for live chat here-- SD TECH
  • SD Tech
    IT IS 53udx10b? is picture 3d looking? red or blue out of place and or bow top or bottom of picture?
  • Hitachi Master
  • 3,459 Answers
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Posted on Sep 05, 2009
How do I get the double vision out of my tv
double vision? is this multicolored. red green blue? is the picture bowed. Have you tried going to setup in customer menu and adjusting convergence, Both manual and autoconvergence.
Oct 22, 2010 | RCA HD52W56 52" Rear Projection HDTV
I HAVE DOBBLE AND TRIPLE VISION HOW DO I FIX IT
This is caused by a blown fuse on the convergence circuit. There will be missing menu items in the service menu as well when this fuse is blown. You must replace the small block type fuse and then enter service menu and converge the television back to normal. This requires removal of the main board, unsoldering the component and replacement, and then alignment.
Apr 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Different color shadows. Double or triple vision
replaced convergence IC.what is the model#?
Oct 04, 2009 | Televison & Video
Double Vision & Bowed Screen
Chances are that the convergence amps are bad.
If those are mounted on a separate board, replacing the board would be the easiest thing to do. Running the magic focus or touching up the convergence in the customer menu may be required.
May 04, 2009 | Samsung HCN653W 65" Rear Projection...
Triple vision
Replace Both of your STK ICs and CK 3 Resistors 2.7ohms.
STKs will be big black ICs.
Feb 16, 2009 | Samsung HCM5525W 55" Rear Projection...
Tv bows
I have the same TV and just finished having my TV repaired for the same problem. I was unable to converge the colors even in the advanced convergence setup menu. The lines were bowing so far that adjustment was not possible. I had to replace the vertical and horizontal convergence controllers located on the main electronics panel. They require a lot of soldering and should be done by a professional. Unfortunately this is a common "maintenance" repair that happens every 5-7 years, depending on the usage, costing around $500.00 for in home repair. DO NOT USE YOUR TV IF THE CONVERGENCE IS BAD AS IT MY CAUSE THE POWER SUPPLY TO BLOW resulting in addition repair costs.
Sep 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Apex gb55hd09w triple vision
Go in and find the conv ICs, they will be mounted on a
big heatsink and the wires going to the conv yokes will
most likely plug in somewhere closeby.
Conv ICs are the workhorse of the CRT RPTV, and it is
not unusual at all for them to need to be changed out
at some time in the life of a CRT RPTV.
Mr Bob
Comment by MrBob84, posted on Feb 04, 2008
PS -
The wires for the conv yokes at the CRT necks are the
thin ones. The thicker ones are for the hor and vert
sweeps, which must never be disconnected from their
circuitry during CRT operation.
If your beam loses sweep on any of the CRTs, it will
instantly score/gouge your phosphors on your CRT faces,
vaporizing the phosphors there and ruining the CRTs.
The beam is very powerful, but in normal operation
moves incredibly fast, not damaging anything. Any
slowdown of the movement of the very powerful beam that
draws the picture, acts like the searing vaporizing beam in Tom Cruise's War of the Worlds.
Feb 04, 2008 | Televison & Video
Triple Vision
One of your convergence output IC's has stopped working and needs to be replaced. This is a very common problem in projection TV's. The IC should be replaced and the convergence circuits realigned by someone with experience in repairing projection TV's.
Aug 04, 2007 | Samsung PCN5425R 54" Rear Projection...
Convergence problems with model#9P6040C101!
They are large black colored IC's with the markings of STK392-xxx (xxx could be 110,120,150) There could be open resistors as well and you have to make sure if you do replace the IC's that you apply heat sink compond to the back of them otherwise they will prematurely fail.
May 03, 2007 | Philips Magnavox 9P6034C 60" Rear...
Hitachi 53UDX10B 53" Rear Projection Television Logo
139 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
