Question about Philips 55PP9401 55" Rear Projection Television
Model NO:60PP9202/17F We have a Phiilips, Model NO:60PP9202/17F. All three bulbs went out at the same time. The sound works but nothing on the screen. Can you help us?
  • scorpio7 Aug 18, 2008
    I have sound and no picture
I have a Phillips Model # 60PP9202/17F, when my wife turns it on it makes a chirping sound but after that there is no sound or picture.
Posted on Jul 07, 2008
Hi: I have a problem with the convergence line up it started when my grand son bumped into it its giving me a double vision blurr.
Posted on Mar 06, 2010
  • 934 Answers
Those are not bulbs, they're crts (cathode ray tubes) but I get the drift. In fact, I just had one of these last week in the shop before the big storm here... Found socket at pos #1202 on LSB had strange black gunk around it. Found socket and plug at pos #1202 both had shorted pins. This cable takes +200v to the crts. Also found open resistor at pos #3817 on LSB (1 ohm 1/2 watt) and you might want to check and/or replace the diode at pos #6802. This should solve your problem...
If any of this sounds a bit greek take it into a qualified shop with my notes above they'll know what it means. It wasn't an expensive repair...
Bill
Posted on Dec 08, 2007
  • 4 Answers
Try www.tvrepairkits.com . I purchased the chirpng kit there and it worked.
Posted on Jan 24, 2010
I have a philips 60pp9202/17f makes chiring sound
Posted on Dec 10, 2009
TV has no picture or sound, when it is turned on it makes a Chirping sound.
Fan works, Lights do not. I replaced a bulb and all three went out..replaced them all and still nothing.Fan still works fine.
What make/model of fan is it? Are you using the correct wattage? You might have a short in the light kit. Remove it and check for any bare wires that might be touching something.
Apr 26, 2015 | Dryers
Lamp error light new lamp
your new bulb may be bad use bulb replacements,com I got a bulb from hem fo r my60" toshiba $125 ups inc. and only had to tke out 6 screws but now im getting white dots
Nov 20, 2012 | Optoma Dmd Projection Display Dlp...
Hi I need a replacement bulb for my WS-55411 Mitsubishi. Can you help me find the right bulb and it's part number? The screen blacked out and sound still works so I assume I need a new bulb. When I shop...
Your model doesnt have a bulb since its a rear projection TV . It has three picture tubes, However loss of video with audio still working is usually caused by a vertical output failure.
Jul 28, 2010 | Mitsubishi WS-55411 55" Rear Projection...
I have a Vizo 50 inch plasma tv...was watching the the other night and screen went out however the sound still works....I have not on screen menus at all. Called Sears and their repair guy charged us $100...
Thats crazy mine just went out today green light comes on screen is black nothing.Tryed to unplug it screen looks like it trying to come on makes a noise something funny on screen nothing. HELP
Dec 23, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
The front turn signals do not work. The rear turn signals do work. The left turn signal went out first, followed by the right turn signal two or three days later.
Sound like U just need to replace the burned out turn signal bulbs. Does your inside turn indicator blink faster than it use to, cause thats an indication that U have a bad bulb.
Hope U find this helpfull
Matt
Aug 14, 2009 | 1995 Nissan Altima
No picture (fan& bulb do not come on) but there is sound
I have a RCA 52inch D52w136D, the power button blinks three times, but nothing happens no picture or sound
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Everything seems fine, but will not record.
buy a cleaning cassette and play three times and then try to record .
Feb 02, 2008 | JVC GR-D33US Mini DV Digital Camcorder
Dryer won't start
Manual might be available on line type in your make and full model. Could well be the bulb that blew. Sounds like the door switch thou i see by other postings some times the filters can cause a similer problem
GUEST. 1. start switch is faulty...oops is it eletronic?it so disregard that. 2 drum is to tight 3 motor or switch on motor faulty
smitty123. Will drum turn by hand??? Can you hear the motor hum when you close the door???
Oct 27, 2007 | Kenmore Elite HE4 Electric Dryer
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb, www.bluestar-online.com
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Philips 55PP9401 55" Rear Projection Television Logo
1,280 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
