Question about Canon Speedlite 430EX TTL Flash
When I put the canon ex40 II in autozoom, it does not show focal length or distance on canon 40D, what am i missing? canon 40D has the latest 1.1.1 firmware
  • retour747 Sep 05, 2009
    Problem solved, when the flash is set for bounce it shows "Zoom--MM" but when the head is at 90 degrees it displays the info
    Problem Solver:
  • 4 Answers
The lens you are using might not support the autozoom. Some Sigma, Tamron and other 3th party lenses are known for these problems. Best solution is to buy genuine Canon lenses, the best partners for your Canon body. (No I'm not related to Canon, I've just seen a lot of these problems with other lenses)
Posted on Jan 04, 2010
I couldn't seem to blur my portrait backgrounds with the canon powershot a1200. can you help me with step by step instructions? does the a1200 have an AV mode at all? thanks
You're trying for what's called a narrow depth-of-field (DoF).
DoF is controlled by three factors: the aperture of the lens, distance to the subject, and the focal length of the lens. This has nothing to do with any particular design, it's simply physics.
The wider the aperture (smaller the f/number), the narrower the DoF. The A1200 does not have an Av mode which would let you control the aperture directly. However, it does have a Portrait mode, which is supposed to give you a wider aperture.
The closer you are to the subject, the narrower the DoF. This suggests that you get as close to the subject as practicable. However, in general you don't want to get too close for portraits as this tends to exaggerate certain facial features, like making noses look bigger.
The longer the focal length of the lens, the narrower the DoF. This suggests that you back away and zoom in. Yes, this conflicts with the previous paragraph.
Unfortunately, it's the actual focal length of the lens that matters here, not the "35mm equivalent" often quoted in the spces. The lens on the A1200 zooms from 5mm to 20mm. Landscape photographers like to use 24mm lenses on their 35mm cameras because that gives them practically infinite depth-of-field, from the flower in the foreground to the mountains in the background. The lens on your camera is shorter than that, so you're going to have a hard time blurring portrait backgrounds.
The best I can recommend is to put the camera into Portrait mode, put as much distance as possible between the subject and the background, get as close to the subject as possible, and zoom in to the longest focal length you have (remembering that the last two are in conflict).
Jun 14, 2011 | Canon A1200 Digital Camera
What is the focal length multiplier for the Tamron 18-270 mm Di-II PZD VC lens on a Canon XSi digital camera?
It's not the lens but the camera that determines the focal length multiplier. On some cameras the 18-270mm lens is an 18-270mm. The XSi's imaging sensor applies a 1.6x multiplier on any lens used with the camera, so the 18-270mm will be approximately 29-430mm.
Mar 05, 2011 | Cameras
What does 35-88mm mean in feet? This is a telephoto lens on a Nikon F50 SLR. Thank you. Amadeus
35mm is about 0.115 feet (a bit under an inch and a half). 88mm is about .289 feet (a bit under three and a half inches). They refer to the minimum and maximum focal lengths of the zoom lens. They have nothing to do with the distance from the camera to the subject.
The focal length of a lens is a measure of an optical quantity. It may or may not have anything to do with the physical length of the lens.
Jan 10, 2011 | Canon 35-70mm f/3.5-4.5 FD Lens
I want to take a picture that is focused on the subject, while everything else in the picture is blurry
What you want is a limited depth of field. There are three factors that control the depth of field: subject distance, lens focal length, and lens aperture. The greater the distance, the wider the DoF. The shorter the lens, the greater the DoF. The smaller the aperture, the greater the DoF.
One problem with compact cameras is that they have very small sensors. This means that they have short lenses. And short lenses mean they have wide depth of field. This is often an advantage, in that more of the scene is in focus. Unfortunately, this works against you when you don't want a wide DoF.
At the short end, the S2's lens focal length is 6mm. This will put just about everything in focus. Even at the other end, the focal length is 72mm. With a 35mm film camera, most portrait photographers use lenses at least 85mm in focal length in an attempt to minimize DoF to draw attention to the face and blur the background.
Unfortunately, the best you'll be able to do is to set the camera to the portrait mode, get as close to the subject as possible, and zoom in as much as possible. I realize the last two conflict with each other, you'll just have to find the proper balance for whatever you're photographing.
Nov 18, 2010 | Canon PowerShot S2 IS Digital Camera
Canon 5D and canon 40D are they type A or type B cameras as per 380 EX manual
Hi Bruce,
You have the latest cameras and they will work with ETTL II with Canon 430EX/550EX/580EX and 580EX II. Earlier models use ETTL and films use TTL.
Hope they are helpful.
atdlee@netzero.com
Jan 13, 2010 | Canon EOS 40D Digital Camera
My scope will not focus it seems like the focal length was somehow knocked out
Yes it will focus. Put the eyepiece with the largest number written on it into the telescope. DO NOT use the 2x barlow. Go outside during the daytime and practice focusing on a distant object.
PS- focal length refers to the distance between the front lens of the telescope and the eyepiece. Are you saying the focuser itself BROKE? If it is missing the scope is not worth fixing, as a new focuser will cost you about as much as what you paid for the scope.
Aug 30, 2009 | Meade Optics
Image Properties shown....
1: bias means voltage a neg or plus I assume the plus means more exposure.
2: focal length in feet ..if not using auto-focus
3: 4.6 feet
4: digital zoom is something I would never mess with but 3072/3072 sounds like a 3 megapixal square.
5: yes set the exposure to a fast shutter or bias in your case like - 3
6: why sure and quite a few pics in 1 minute with the right camera.
May 10, 2008 | Cameras
Exposure problem
Your 40D requires that you use an ETTL-II type flash like the Canon 380-EX. What flash are you using?
Mar 25, 2008 | Canon EOS 40D Digital Camera
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Dec 25, 2007 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Sharpness problem
That should be a very sharp lens, only thing I can think of is that you have a bad copy. It can be sent into Canon where they will fix it.
First, I would try giving it a full cleaning, and taking shots in good light on a tripod at 17-80mm, just to make sure its really the lens
Dec 15, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon Speedlite 430EX TTL Flash Logo
369 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
