Question about Kenmore 63942 Dryer
Gas dyer not heating up
Looking for igniter on kenmore dyer
    Problem Solver:
  • 29 Answers
It is located on the front of the gas burner inside the cone where the flame comes out It is very fragile, do not touch it with your fingers except the white base. and don't bang it around or you will be buying a new one. older machines it was easy to get to because the all had a kickplate to pop of for access many new ones you have take the whole front off the machine to get to it
Posted on Dec 03, 2011
  • Kenmore Master
  • 8,220 Answers
Most of the gas dryers have everything accessible by simply releasing the spring clips atop the toe panel and getting it out the way.
Here are some repair pix with manual
Posted on Sep 05, 2009
I would like to know the year of my Kenmore special edition washer and dyer SM 97 10804-4
Hi C,
Looks like around 2001 according to Serial #.
110 prefix means Whirlpool manufactured this item for kenmore
Dec 29, 2014 | Kenmore Washing Machines
Can I use a 3 prong dryer cord on the Kenmore Elite Oasis dryer?
Most dyers are 220V. If the chord is connected to three terminals as most dyers have, then it would work just fine. Just be sure you connect the ground wire correctly.
Apr 08, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Kenmore Model 97310100
Are the coils getting voltage do you know? Or you can check the thermal fuse to see if its open.
Oct 23, 2008 | Kenmore 62602 Electric Dryer
Kenmore dyer
I have a kenmore gas dyer, it will start to dry then go out and just run. you can shunt it dwn resit the timer the time it needs start it and it will lite for a cycle then go out, short burn, then out. is it a senor???? JW
Jun 09, 2008 | Kenmore 62802 Electric Dryer
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Kenmore 63942 Dryer Logo
114 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
