Question about Flotec Plumbing
I got 1 year old flotec 3/4 hp pump and it take
I got 1 year old Flotec
3/4 hp pump and it take too long to shot off
  • 32 Answers
I have had the same problem there are a few things that can cause it to take longer to shut off, if you are running a sand point well that's usually a sign that the sand point is clogging up,if you have a sistern or a dug well check the screen on the end of the suction pipe,another possible cause is the water level has dropped low enough the pump is having to work harder to pull the water up, you should also check your pressure tank and the points for the pump if the points are sticking the pump will keep running till it builds enough pressure to trip them.Check for leaks in the suction line, if it is sucking air that would cause it to run longer to.I hope these suggestions will help fix the problem. Have a great weekend
Posted on Sep 05, 2009
Why isn't my pump pumping any water
Flotec FP4012-10 1/2 HP Shallow Well Pump Jet ...
www.amazon-associate.com/Flotec-FP4012-10...Well.../B0002YXB14?...
Find helpful customer reviews and review ratings for Flotec FP4012-10 1/2 HP ... After realizing the failure was due to a high amount of sediment in my well I ...
Aug 30, 2015 | Flotec Pump FP4022-10
STORES THAT SELL FLOTEC 1/3 HP MODEL NO. FPSC2200A-08 115 VOLT 60 HZ 9AMP SUBMERSIBLE PUMPS
Your best bet is to get off this site, go to Google or Yahoo or any other search engine and type in "Flotec Pumps" and you will get several thousand places to shop.
Aug 03, 2012 | Flotec Plumbing
My dog chewed the power cord off my FPOS1800A-08 submersible pump, From whom do I order a new cord.
After searching, a clear answer was found ... if the cord replacement exists, it costs a lot.
Flotec has a contact-us form that requires your personal information
http://www.flotecpump.com/
That being said, flotec FPOS thermoplastic sump pumps have pdf parts list.
Parts list shows cord as replacement part.
However, I don't see the FPOS1800 listed
http://www.flotecpump.com/pdf/FP0S6000A_08ReplacementParts.pdf
Flotec sell sheet shows FPOS1800 but does not show parts
http://www.flotecpump.com/pdf/Pg_6_2006.pdf
Website below sells flotec parts
http://www.pumpagents.com/FlotecPumps/flotec-pump-part-list.html
Random cordset price-check shows $46 for a cord
Another cord was $80
Another cord was unknown
Nov 14, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
Flotec 1/2 hp motor only buzzes when circuit breaker is turned on...
hi i had the same problem last week mine turned out to be two things 1 the filter was blocked and 2 the capasitor was shot and i had to change it if this the case never downgrade but y can always upgrade hope this helps
Nov 14, 2009 | Flotec Corrosion Resistant Shallow Well...
I need a motor for flotec shallow well pump unit #FP7100-08.The motor #S48D02AO3.WHERE CAN I FIND ONE AND HOW MUCH.Thank you Greg
Save yourself time and effort, replace the entire unit. I speak as a guy who has lived with a well for more than 35 years.
If you put a new motor on a old pump what do you have? A new $300.00 motor on a $worthless old pump. Spend the $350.00 and replace it.
Oct 27, 2009 | Flotec Corrosion Resistant Shallow Well...
3/4 pump -is pumping water - but a a slow pace
Re prime the pump. Make sure the suction line is completly flooded so it will take a good suction from the well.
May 18, 2009 | Flotec Corrosion Resistant Shallow Well...
I need a power cord for my 1500 gph 1/6 HP Flotec submersible pump. where can I get one? Cat # u2 Serial # 50833
Get ready for sticker shock:
http://www.abtecparts.com/simer_cords.htm
Simer and Flotec parts are interchangable.
Feb 17, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Plumbing Logo
201 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
