Question about GE 29897GE2 Corded Phone
Answerer won't pick up
Everything is set on the phone- including the time, date, greeting. The phone is set to answer on 4 rings. After the 4th ring the answerer beeps and then PLEASE WAIT.... appears on the screen and greeting does not play and call is disconnected. The time and date reset to a flashing 12:00 an 1/01. Please help/.
Hi Otis,
I had the same problem after I had a new cable installed. I called the GE Customer Service: 1-800-720-2094 and spoke to a tech - here's what I was advised to do:
1. Unplug power from the Wall
2. Unplug power from the phone line
3. Wait 10 minutes
4. After 10 minutes, reconnect in REVERSE ORDER
5. Reconnect Phone Line FIRST
6. Reconnect Power Cable LAST
** I asked what happens if it still doesn't work. The tech asked me how long ago did I purchased the phone. I said 2-3 yrs ago. Then he said: "If it doesn't work, then the unit is defective". That's when I became skeptical. Anyway, try the above steps as I was advised and see if it works...I'm currently doing it and waiting for 10 minutes before reconnecting the unit in "reverse order". Good Luck.
Posted on Feb 19, 2008
I lost the book how to put numbers in memory.
Posted on Jan 07, 2008
THE ANSWERING SERVICE CUTS IN BEFORE I AM ABLE TO GET TO THE PHONE
There should be a switch towards the bottom on the right hand side
Setting ring time switch The ring time/toll saver switch allows you to set the number of rings the caller hears before the answering system plays your outgoing message. You can set the switch to answer af ter two rings or af ter four rings. Once the greeting has star ted, you can stop it when you pick up the call at the handset or base. In the TS (Toll Saver) position, the answering system picks up af ter two rings if you have new messages, and af ter four rings if there is none. This way, if you call long distance to check your messages, you can hang up af ter the third ring to avoid billing charges.
Feb 28, 2011 | Uniden Cordless Phone
Have problem changing auto answer to longer than 3 rings
Press and hold the SET button to enter the change mode. The unit announces the current time and day. Press SET repeatedly until the unit announces the rings to answer. Press and release NEXT or PREVIOUS until the unit announces the correct number of rings for the answerer to pick up. Once the rings to answer is set, press SET to enter the incoming message length menu.
If you need a manual, you can download one here.
Oct 31, 2010 | GE 29868GE1 Digital Answering Machine
How to set number of rings before answering turns on
http://www.home-electronics.net/USER-GUIDES/26992_DOM_EN_CL_IB.pdf
Jun 10, 2010 | Uniden Cordless Phone
GE answering machine 29870 How do I change the number of rings beffore the machine picks up
SETTING THE RINGS TO ANSWER
The unit announces the rings to answer. To change,
press NEXT or PREVIOUS. To set and go on to the next
item, press SET.
1. Press and release NEXT or PREVIOUS until the unit
announces and displays the correct number of rings
2. Once the rings to answer is set, press SET to enter
Mar 24, 2010 | GE 29870GE1 Corded Phone
Answering machine not picking up on 4th ring
Check to see if the battery needs to be changed. I did, and it worked for me.
Dec 16, 2009 | Radio Shack (43-3829) Digital Answering...
Wanted to know if i can check messages by calling in
CLICK HERE for the user manual.
The following is on Page 19....
REMOTE ACCESS
You can access your answerer from any touch-tone phone
by entering your 4-digit security code (the default security
code is 0123). The remote functions do not work with rotary
or push-button pulse-dialing phones. You can cut out the
wallet-size remote card near the back of the User’s Guide
so you know the touch-tone commands when you're
picking up messages from another location.
To access your answerer:
1. Call your telephone number.
2. After you hear the beep that follows the greeting,
enter your 4-digit security code. To bypass the
greeting, you can enter your 4-digit security code at
any time while the greeting is playing.
3. The unit plays the remote menu after the correct
security code has been entered. Menu selections can
be made at any time while the menu is playing.
NOTE: The unit answers on the 10th ring when it is
turned off or the memory is full. To access the
answerer, enter the 4-digit security code after the
beep. If memory is full, play messages and erase
some of them to restore memory. If the answerer is
off, press 2 to turn it on.
NOTE: After the unit plays the remote menu, it will
wait several seconds for a command, then disconnect
Thank you for using Fixya - a FixYa rating is appreciated!!
Jan 28, 2009 | GE 29869GE2 Digital Answering Machine
Increase numbers of ring
If the machine won't go past 4 rings (which it should somewhere in the answering machine settings menu) you could always change your greeting to a message that tells the caller to wait a few more moments for you to answer, while you get to the phone....
Jul 15, 2008 | Uniden TRU8885 Digital Answering Machine
GE 29893GE1-B Digital Answerer Problem
G.E.speaker phone model#29322GE1-a how to program other numbers in phone
May 17, 2008 | GE 29893GE1 Corded Phone
GE Telephone answering machine will not work
I'm assuming this is a digital recorder and does not use a tape. Any chance the memory is full and you need to erase messages to free up space for new recordings?
Jul 01, 2007 | GE 29897GE1 Corded Phone
GE 29897GE2 Corded Phone Logo
200 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
