Question about Nokia 3220
No power my problem is my nokia phoni 3220 has no power and then i used multitester to see what the problem but it has continuity vice versa
Booss no power 3220 heill me
Posted on Sep 23, 2011
    Genius:
  • 1,011 Answers
You said you found continuty, where did u find continuty? Did you checked the battery terminals? if you checked the battery terminal and found continuty then it should be not like this. its mean that something is short inside. Most probably the charging IC that is responsible for the charging and the power, with addition of some SMC (Surface Mount Components).
Dear, the continuty is part of checking, if you can u need to check it through Voltage supply including current output etc... its a task to do..
if you cant, better way is to get it done through an Expert at shop near u.
Sometimes, it happens that the fault is a little but can be expended through improper dealing.
hope u understand.
goodluck dear,
Posted on Sep 05, 2009
Please help me,i have nokia 3220 but i forget security code,imei : 3562360055455200521037 help please
You can use Master Reset Code to Reset your mobile.
The master reset for your Nokia 3220 is 3441544421 .
I generated the code for your Phone using Unlock-Free.com
Dec 19, 2012 | Nokia 3220
I need the restriction code for nokia 3220. my imei num is 359396/00/091073/6 please and thanks
Restriction code means Network Unlock code to unlock the Nokia 3220 to use with any GSM Network sim cards.You can get the restriction code from the site
Simpleunlocking.com/nokia-3220/rs16wp9/ and unlock it.
Dec 15, 2011 | Nokia 3220
What's your problem?i need the restriction code for nokia 3220. my imei num is 359396/00/091073/6please and thanks
You can use the restriction code to unlock the Nokia 3220 from the network lock,you can get the Restriction code from the site Simpleunlocking.com/nokia-3220/rs16wp9/ and unlock it.
How can i download from pc to mobilephone
You have a few options;
  1. Purchase a USB Data Cable and download Nokia PC Suite from Nokia website. You can then transfer items from your PC to Phone and vice versa using the Data Cable.
  2. Purchase a USB Bluetooth dongle and downbload Nokia PC Suite from the Nokia website. You can then transfer items from your PC to Phone and vice versa using the Blutooth.
  3. Purchase a Memory Card Reader and simply drag and drop items onto the memory card using your PC, then put the memory card back in the phone.
May 21, 2010 | Nokia 6500 Slide Cellular Phone
Compatibility of Nokia 3220 with Nokia PCsuite
It is compatible but the phone may refuse the connection because it uses the DKU-5 cable.
Jan 29, 2010 | Nokia 3220
My Nokia 3220 is continuously buzzing when I inserted the battery. Set was sank in a bathtub and soaked.
remove the battery and flip the phone upside down to air dry. Check where the battery goes to see if it was water damanged by the white dot being pink.
Sep 26, 2009 | Nokia 3220
Nokia 3220 no power totally shut off
check battary connection, proper recharge, also check battary contact & connection in cell phone.
if still no resonse, that means, there are a software or chip problem, solve only at nokia care or other mobile care shop.
Jun 25, 2009 | Nokia Handsfree Car Kit For 3200, 3205,...
Nokia 3220 getting swithc off
software upgrade fixes these issue 95% of the time , if it doesnt well you will need to get it fixed by someone.
Jun 15, 2009 | Nokia 3220
Hai sir nokia 6030 set ded problem
have you tried changing the battery? if not, change it first...
still not ok, open the housing and check the switch botton...use a multitester... there should be no continuity when not press.... there should be a continuity when pressed. still no luck... visit your local cellphone repair shop
Jan 22, 2009 | Nokia 6030 Cellular Phone
Nokia 3220
SOMEONE CHEAT YOU
May 13, 2008 | Nokia 3220
Nokia 3220 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
