Question about Pentair Minimax NT Heater
E02 error and heater will not start. Service
E02 error and heater will not start. Service light is on
  • kingtut Jun 29, 2013
    Just bought the monaco layzspa. e02 from very begining.. did all the manual told to do. filters are new etc... no leaks or anything. could it be of fresh water at 10c very cold for the heating system? the bubles work properly. bout this thing for my 3 year old kid because of the heating system and it refuses to work
    Champion:
  • 246 Answers
High limit is open this is due several factors like slow water .pump on low speed or dirty filter, also hard water, or assembly valve not working properly so make sure the filter is clean check the water chemistry an last check the valve assembly. make sure plumbing is correct water in and out from the heater
Posted on Sep 19, 2009
What's error code e02 Whirlpool water heater product # 100028736
E02 Water temperature exceeded high limit Switch the two house circuit breakers dedicated for the water heater to OFF and then press the reset button located behind the control panel on the water heater. Flip the house circuit breakers to the ON position. If error returns, call a service technician for assistance.
Dec 24, 2016 | Whirlpool Washing Machines
E02 flashing
Whirlpool breadmaker e02 error Questions & Answers - Fixya
www.fixya.com > Forum > Tags > breadmaker e02 error
Ask your Whirlpool breadmaker e02 error questions. Get free ... I am getting F01 andE02 flashing errors and the machine will not go into spin cycle . How bad is ...
Nov 28, 2015 | Kitchen Appliances - Others
Problem with washing machine
it could be the heater if its manual ot the cabon brush benearth situated in the motor,,,,,,,,,,,,b
Jan 26, 2015 | Zanussi Washing Machines
Heater has been running and heating, but getting E02 error and HI
sounds like a water flow issue check your bypass valves check for clogged filter or thermal regulator ,or manifold bypass
May 17, 2014 | Pentair Minimax NT Heater
F06, E02
I think these problems are related to water inlet, take off the hoses from the back of washer and you will find a screen in the outlets clean with old tooth brush until clear.
Feb 19, 2014 | Whirlpool WFW95HEXW Duet 5.0 cu. ft....
How the error e02 on fit king treadmill be repaired
Dear sir,
I am having a treadmill of Fitking model no. W590 it is showing error code e02.
Kindly suggest what to do. I am eagerly waiting for ur response
Rgds
Yash Pal
Jul 15, 2013 | Exercise & Fitness
My Eternal Hybrid natural-gas hot water heater, Model Number GU195 stopped working, and gives a E02 error code. When the heater automatically attempts to burn, the natural gas doesn't, until the...
I'm having a similar problem. My water heater is Eternal GU195S. It will heat up the water it's in the tank so I will get hot water for a few minutes. Then whenever the system tried to heat up on-demand, it will not heat up and gave E02 error. If I stopped drawing water, the E02 error will go away and the temp setting I had will come back on. What could be the problem? I currently took it out of service and set it up outside my work shop for testing. Thanks.
Sep 08, 2011 | Heating & Cooling
DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Apr 23, 2008 | Panasonic Workio DP-1820E Copier
Pentair Minimax NT Heater Logo
2,442 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
