Question about Garden
I need to remove the head from my Ryobi Weed Viper line trimmer for replacement. Could you please assist? Many thanks.
#1 Taper
  • 1041 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
SOURCE: how do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Posted on Aug 18, 2009
mrgauge
  • 17 Answers
SOURCE: Want manual for RYOBI 31 cc 700r weed eater
Try this link:
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/700r_1.html
Posted on Oct 01, 2009
Testimonial: "Thank you! Just what I needed."
SOURCE: how do I replace the pull cord on a ryobi #ss30 weed trimmer
You need a long skinny T25 torque driver (sold in a pack at Lowe's with 3 other sizes.)
Take off the 4 screws in the back to reveal the piston. Get a wooden dowel (or a wooden spoon if your wife isn't around) and stick it in to the piston to block it from spinning.
Now take that T25 and stick it in to the front pulley (cone shaped silver item that is preventing the housing from coming off) turn to the left and it should come off.
That should come off to reveal about a 1"x1.5" piece with a spring wrapped around it. That can also turn to the left and come off with an adjustable wrench or pliers.
Once that is off the housing should come away and you'll be able to get at the pull cord after removing 4 more T25 screws.
Posted on Oct 14, 2009
  • 4044 Answers
SOURCE: I cannot remove the head
Being new, I'd return it if the the head flew off. When you say head I see the Engine head coming off and the engine be a total mess. What part are you actually talking about. Is it plastic or aluminum? Here is a link to PDF doc that you can download. If your talking about the part with the string that cuts, which I think you are, you need to screw it back on and make sure you have a something that is locking the screw in place while you screw it down. You can use the special tool that should have been included with the weed eater or use a Phillips head screwdriver in the locking hole to hold that mounting bolt steady for you. I found a pretty good picture of the process in the manual I found here :
http://www.filemeta.com/preview.php?url=687474703a2f2f6f647265662e636f6d2f7064662f52796f62692f383930722d6f776e6572732d6d616e75616c2e706466&fname=393536312038393072206f6d2028656729&country=ca&filetype=pdf
Posted on Jul 05, 2010
My Ryobi weed eater the head of the weed eater is hard to turn and the engine doesn't want to turn it
problem most likely is that the cable drive for the head is twisted up inside the tube and jamming the operation
you have 2 options
remove the head from the tube and pull the cable out or
remove the tube from the power head and pull the cable out that way
new cables are available from your local mower shop
if the cable guides inside the tube are damaged , consider replacing the bent tube with a straight tube , then you can use more attachments for the head
Sep 20, 2016 | Ryobi Garden
Electric line trimmer: line simply cuts off and disappears after a few seconds; can this be that the line is too thin? It is a prewound purchased replacement, so must be wound the right way. Has a...
you can replace the head of the unit as it is bolted on left-handed threads, Lowes, HomeDepot, Wally world, Kmart, basically any discount store sells replacement heads for weed-eaters. hope this helped Tim
Nov 20, 2010 | Ryobi 15" Electric Factory Reconditioned...
Have a Ryobi weed wacker 725r 31cc click link Trimmer Plus. No more line-can't figure out how to remove bottom to replace the line or what kind of line to replace with. Deceased husband lost directions...
i also have a ryobi weed wacker. if it is the same. you don"t have to remove the button. line up the 2 arrows one on wheel with bumpy edges and one by the button. you should see 2 holes feed a 2-3 foot piece of line into the hole the line comes out of for cutting and it should come out of a curved holw on the bottom by the button .tuck the end into a small round hole . pull line tight (tug on the section that you cut with). wind the string by turn the ring around the button. til desired length. if this doesn't work. google you model # and look for a manual (manual for ryobi weed wacker model # ------------.)
Jun 09, 2010 | Garden
RYOBI GAS WEED TRIMMER RIPCORD TANGLED
You should be able to take the housing loose with about 4-6 torx head bolts/screws and get in there and untangle the rope. May not even have to take the housing off, just loosen it. Good Luck!
Nov 18, 2009 | Ryobi Garden
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
Need to remove weed line (recessed inside) so I can install new 1
If i know which head you are talking about then, it is a self feed that you wind the line in at through the holes right?? the black center nut comes off. using pliers twist it off, it is threaded.
May 30, 2009 | Ryobi 15" Electric Factory Reconditioned...
Remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
May 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
641 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
