Question about Canon PIXMA MP160 All-In-One InkJet Printer
Error code MP170
Where can I found out what error 2,2550 is for Canon Pixma MP170 when trying to scan
hi i'm Pauline Revell
i'v just brought a canon pixma mp180/mp160. i have installed the software and everything. the printer works fine but the scanner dose not. it trys to scan but a thing comes up that says its not plug in or cable not connected with numbers. the canon is pluged in of cours becasue the printer works. could some one help me please. mya-lee123@westnet.com.au
pixma mp180/mp160
  • 5 more comments
  • Pixamp160 Dec 10, 2007
    I have this printer, PIXMA MP160 All-In-One InkJet Printer
    with the error code 2,155,0. I also have a new HP computer with the new VISTA operating system. MicroSoft says I have a Canon problem. Everything works except the Scanner. In fact I've tried to up date the driver for the scanner. The Operating System repeatedly informs me that the best driver was already installed.
  • Anonymous Dec 22, 2007
    I have a Pixma MP470 with the same problem, using XP-SP2. Have deleted and reinstalled printer with no success.
    jackvd1@yahoo.com
  • Anonymous Feb 18, 2008
    cannot scan. error code 2,155,0
  • Anonymous Aug 18, 2008
    how do you scan to a mac?
  • ckar_thi Aug 19, 2008
    kindly see the attached image,and give me some solutions.
  • Anonymous Nov 26, 2008
    i need help to
  • pajnal May 11, 2010
  • 29 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-27
Posted on Sep 04, 2009
Referring to the solution suggested in http://www.pcwelt.de/forum/scanner/265043-canon-pixma-mp-600-kommunikationsfehler-beim-scannen.html (for german readers) I switched my 3.5m USB-cable to a 2m long USB-cable and got rid auf the error 2155 while trying to scan with my MP170 on a Vista Ultimate PC.
Posted on Feb 24, 2008
I have widows vista and i purchase canon pixma mp180/mp160 but it not woking with this window
Posted on Jan 03, 2008
Yes i have same problem
Posted on Dec 30, 2007
  • Canon Master
  • 1,113 Answers
2 Suggested Answers
winxpmain
  • 14 Answers
SOURCE: error code MP170
GET YOUR SOLUTION DIRECTLY FROM CANON. VISIT
www.canon.com/printer/prob3178hgu8/solution
102
Posted on Dec 15, 2008
My canon pixma mp170 says check printer on the screen with error code 5200 and the alarm button is flashing
Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
Dec 16, 2009 | Canon PIXMA MP170 All-In-One InkJet...
What does the trouble code on a cannon printer
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Thanks.................
Jul 17, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Instillation
I am having the same problem. How can I install printer?
Jul 31, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Error code MP170
CHECK THIS OUT if it can help:
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
Nov 06, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon MP170
primeramente me salio 5100 pero luego paso a 6000 no se lo que puede pasar ya que no se mueven los cartuchos y no hace el reseteo cuando la enciendo y solamente me sale COMPRUEBE IMPRESORA Y SALE 6000 ERROR. en espera me sean indicados los problemas que se puedan subsanar un saludfo
Feb 28, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
618 people viewed this question
old marine
old marine
