Question about Frigidaire Dishwashers
I have a greasy buildup on my dishwasher filter.
I have an almost clear,whitish greasy buildup on my dishwasher filter. It will not wash off with hot water and soap and I cannot even get ot off my hands unless I use a waterless hand cleaner such as "Fast Orange". Why and how is this on my filter?
    President:
  • 2,976 Answers
It is the grease left on dishes or pots & pans. It can be cleaned off using a good regular dishwashing detergent like Dawn in the sink, not in the dishwasher. To prevent it, scrape the dishes & pots better, and if possible, turn the temperature of the hot water up a few degrees. You should also change dishwasher detergents to a liquid, with a built in water softener.
Posted on Sep 05, 2009
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
LG dishwasher
If you're sure you're using enough soap, check that your hot water is connected and that you're using a hot-water wash (some dishwashers have a cold-water option, this will often give unsatisfactory results if washing greasy dishes - especially beef fat).
Jul 02, 2014 | Computers & Internet
My dishwasher spray arms were clogged with calcium buildup so I cleaned one and replaced the other. I also removed the fixed disc-shaped device underneath the lower spray arm and found the particle filter...
you may want to check your hot water tank. It may need drained and cleaned, Or you may have the rod in the tank disintegrating. Also check you water faucet areators to see if they have calcium pieces too.
Feb 10, 2011 | Maytag Dishwashers
Last three loads have not cleaned my glasses - cloudy and lipstick still on them. Using JetDry and Cascade powder. What can I do to fix this?
You probably have a soap buildup. Try running it without any dishes in it. Let it fill up and start washing a few minutes, the open the door and see if there are suds. If there is, pour a half cup of cooking oil into the water and let it complete the cycle. That will clear the soap buildup. Aside from that, keep using jetdry and make sur the water going into the dishwasher is hot (run kitchen tap until it's hot before starting dishwasher to clear the line)
Mar 28, 2010 | Dishwashers
I think that the problem is that these washers use too little water for rincing. Concentrated detergent residues are drying-up, solidifying on internal surfaces, including exhaust tube, and smell like...
I've got a Maytag with a similar issue.. Try this: Take a 1/2 cup of automatic dishwasher soap powder (Such as Cascade) and toss it into your washing machine without any clothes in it.
Run a whites, hot water cycle with an extra rinse to see if this will break down some of the buildup and remove the smell. You may want to run a second cycle without adding soap to clear the drain lines.
Dec 02, 2009 | LG Washing Machines
Siemans dishwasher not draining
the water in the bottem of the machine under the mesh filter is normal. it acts as a lubricant for both motor impeller and drain propeller. if its greasy then try using only 1 tablespoon of powder soap from now on. now if the water level is ever above the mesh filter after a complete cycle, then you have a drain problem
May 25, 2009 | Dishwashers
Bosh error code E02
Hi. I had the same problem with my Bosch washing machine and called Bosch...was told the same thing...$99.00 for service call. I managed to fix my problem by doing the following:
  • Removed hot & cold water supply hoses.
  • Took filter screens out of both hoses.
  • Removed filter from cold inlet on back of washing machine. I noticed some oily buildup on both of the cold screens so opted to not put any of them back in.
  • Then I put hot & cold water supplies back on the wall hookup, but crossed the lines where they came into the back of the machine intentionally so that the hot water line fed into the cold side of the washing machine and vice versa.
  • Then I ran a couple loads on "cold" which was actually hot water coming in to the machine.
The reason I did this was that I figured there must be some more waxy buildup inside the machine in the cold lines and hoped the hot water would melt it like when you rinse a greasy pan under hot water. IT WORKED!!! I hope this helps you.
Sep 29, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Cleaning washing machine
THERE ARE COMMERCIAL WASHING MACHINE CLEANERS ON THE MARKET. YOU CAN ALSO USE AUTOMATIC DISHWASHER DETERGENT IN A HOT WASH TO CUT GREASY BUILDUP IN THE WASHER. BE SURE TO GET THE WATER A LEAST 120 DEGREES TO ACTIVATE THE DETERGENT. YOU CAN ALSO USE A BLEACH BATH TO CLEAN THE WASHER, BUT DON'T COMBINE THE BLEACH WITH ANY OTHER CLEANERS. IT CAN BE TOXIC.
Apr 03, 2008 | Kenmore 22422 Top Load Washer
Water not hot
Dishwashers are suppose to be hooked up to hot water. If you had hotter water it would clean just fine. 120 deg or more!
Nov 01, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Kenmore Dishwasher
If you have either dry bearings in the motor or sticky grease buildup in the pump bearing/seal, it can cause the motor to stick rather than rotate on startup. More likely to be greasy crud buildup. The best you can do without disassembling the entire unit is to circulate a good degreaser product in a wash cycle, such as 409 or PurplePower. On the off chance (very small chance) it would degrade plastic parts, only run degreaser wash cycle for 5 minutes or so before draining it and running rinse cycle.
Nov 11, 2006 | Kenmore 24 in. 15149 Built-in Dishwasher
Dishwashers Logo
294 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
