Question about Sharp AL-1000 Copier
HP laserjet 2100 prints pages fine, but has "ghosting" and duplicating text and images several lines down from original text/image. Recently installed new HP toner cartridge and was working fine for about 150 pages... then this ghosting started. Tried the (2) "cleaning" processes described in manual. Problem did not go away. Do not have another cartridge to try to see if the cartridge is causing the problem. Any suggestions would be appreciated.
  • Frank Kuhlman Sep 05, 2009
    Odd... turned printer off overnight. About noon today turned it back up on and printed about 20 pages. They all printed perfectlfy. DUH! Go Figure.
    Crossing my fingers and hoping the "ghosts" don't come back.
    Ed
  • 335 Answers
Sounds like a bad drum on the cartridge. Contact HP, and they will probably replace it free, or maybe help you to troubleshoot.
1-800 HP-INVENT
Hope this helps!!
Posted on Sep 05, 2009
Testimonial: "Odd thing. I turned the printer OFF last night and turned it back on today around noon. Since then, I have printed about 25 pages of text and graphics. All the pages printed perfectly... no ghosting. I have no idea how the printer "repaired itself", but it seems to have. I'm crossing my fingers that this problem will not return. Thanks anyway for your help. Ed"
HP LaserJet 1020 PATCHES ON PRINT OUT
if the patches are random, and not ghost images duplicating down the page, you may need to take out the toner and gently shake it - tilt it right 90 degrees, then left 90 degrees, etc a few times to redistribute the toner...
failing that, the toner could be almost empty.
otherwise, check and see if they are duplicating down the page.. ie the same image defect 3 or 4 times down the page, if so, it is probably one of the drums.. toner or fuser drum...
Hope this info helps.
May 15, 2012 | HP LaserJet 2550L Printer
HP LaserJet M5025 MFP scans too light. Under default job options, image adjustment, darkness set to 3. The printer was sent to us upside down. We recently installed a brand new cartridge. Any suggestions?
If you print the configuration pages from the administration>information menu and they look dark then you know that the printing system is working fine. If they are light as well, then it is possible that being shipped upside down resulted in some dirt getting into the laser scanner. The image original settings are kind of wonky, in that it is backwards to normal assumptions. Darkness refers to the actual orignal you are scanning, so in most cases if you have lighter origjnals then you need to set darkness lower. As well, check whether the image type is set for photo or text. Setting for text will result in darker scans.
Jun 18, 2011 | HP LaserJet M5025 MFP Printer
Hi, my printer is printing a test page but it's not clear at the left side of my page.what could be the cause of this problem?it's hp laserjet 2100/m/tn
This may be one of several things.
When you rub your finger over the unclear parts, does the image come off and feel grainy.
If so your fuser unit is not fusing the image corectly.
Have you tried another drum unit in the machine, it may be that the problem is on the drum unit and that the image is not transferd corectly.
Feb 10, 2011 | HP LaserJet 2100 Printer
Ghost images of the same printing repeated down the page
Run a half test. While printing a few pages, open the cover, pull out the toner and look down at the paper. If you see the ghost images replace the toner. If you don't see the ghost images, replace the fuser.
Sep 11, 2010 | HP LaserJet 1020 Printer
The printer is printing duplicate text in other areas of page randomly
If the duplicate text is faded or a "ghost" image from higher up on the printed page then your fuser film is going bad. I would try a different toner cartridge first just to eliminate that as a possibility but it sounds like fuser film. You can get a new fusing unit or see if a printer/computer service company local can replace just the fuser film. It is about 50% cheaper to do just the film as the rest of the fusing unit is good.
Jan 08, 2010 | HP LaserJet P3005n Printer
Ghost printing preceeding page images and or text
1.Most likely is the fuser assy, depending on what your page count is. 2.Could also be your toner cartridge especially if it is a reman
Dec 08, 2009 | HP LaserJet 4345mfp Printer
Ghosting
fuser could be faulty
Jun 12, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet 1012 Printer prints ghost images
I ran the hp toolbox "cleaning" mode too and it did not help the problem at all. I still have a dark smear concentrated in the middle of the page, and ghost images repeated lighter all the way down the page.
Aug 21, 2008 | HP LaserJet 1012 Printer
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
Ghost images
Is it from the most recently printed page, or is it the same image avery time regardless of what you print? It sounds like your drum or roller (I'm not sure about the exqact term in english) might be the issue. Have you somehow managed to "force" a printing without paper in the printer?
May 18, 2007 | HP LaserJet 4 plus Printer
Sharp AL-1000 Copier Logo
208 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
