Question about Pyle PLTDN71 Car Video Player
Can some1 please tell me how to connect all the wires with my chvy wireing harness just to make sure im doing it right, because the unit doesn't turn on...
  • 733 Answers
Red-power(keyed), yellow-power(constant), black-ground. If you're having problems installing it, try powering it on with your'e car battery, if that works you have a blown fuse in the system.
Posted on Sep 05, 2009
Wiring JVC car deck
Do you have factory infinity sound. If you do you need a another harness or bypass that infinity system. Also What year is the truck. I know for a dodge ram after 02 is a canbus system. When wiring in the harness leave the blue remote wire alone do not connect from radio harness to the harness that connects to factory harness. Unless you are running to an aftermarket amp. There is a brown wire also that you should not connect leave the remote blue and brown wires alone. this is atleast on a 02 dodge 1500 or newer and 03 or newer 2500+. not sure if this will solve your issue but it fixed my buddies.
Apr 29, 2013 | Dodge Cars & Trucks
I need to wire a 4 prong wire harness for a trailer. What color wires are the left/right lights, ground and running lights
im not sure but they make a unit that plug into the harness direct without splicing into the wires
May 12, 2012 | 1995 Chevrolet K1500
Brake lights don't work on my 2010 FXDWG and my right turn signal doesn't work either. There is a key icon on my speedo that is on in red.
Hi Ed, always check fuses and bulbs first for broken filaments. Then check the connection at the rear fender wiring harness, inspect for corroded, broken or loose pins. Use a dab of dielectric grease and repair as necessary. Check your brake relay if you have one , check your brake light switches for continuity, some models rear turn signals were single filament bulbs only, no running light. If all else fails get out your test light and start tracking the power wire from the harness connection. You could have a faulty turn signal module or a bad turn signal button/switch, remove it from the switch housing and check for continuity, check your wiring and connections from the turn signal switch to the turn signal module with a testlite. Make sure all wires are not worn or pinched and connector pins are not corroded, broken, or loose. For a free wiring diagram please visit the website below. You may also need an alarm reset. Harley Davidson Wiring Diagrams and Schematics
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Oct 07, 2011 | Harley Davidson FXDWG - FXDWGI Dyna Wide...
2005 chevy cavalier after market radio has no power, im installing a pioneer head unit in my car, i bought a wairing harness connected it to the wiring harness for the new radio, im getting power to the...
No, make sure the vehicle key is in the aux or on position. If this still doesn't work, recheck the wiring. Also, make sure you have a good ground.
Sep 03, 2011 | Car Audio & Video
I have this model of Head units. I have used crimp connects to connect the unit harness to the car harness. Hooked up my turn on wires and rca cables. Now my head unit when turned on shorts in and out and...
For starters, I want to make sure. You did purchase a wiring harness that "plugs" into your vehicle, right? If not and you are attempting to hardwire to your vehicle, STOP! You run the risk of frying your entire electrical system. If you purchased a harness you can crip the wires from your head unit to the harness and the harness plugs in. DO NOT crip wires directly. You are experiencing just a little of what can happen. However, if you did purchase the correct harness, you need to check all our crimps again. Hope this helps.
Aug 21, 2011 | Car Audio & Video
I have a kenwood krc-2001 and im wondering what and i need help
I'LL MAKE THIS VERY EASY FOR YOU, IT WILL ONLY COST YOU ABOUT $25 MAYBE LESS. JUST GET A WIRE HARNESS FOR YOUR CAR, PEPBOYS OR ANY AUTO STORE, JUST TELL THEM THE YEAR AND THE MAKE OF YOUR CAR AND YOU WILL BE SET, THE WIRING IS COLOR CODED, MAKE SURE THE HARNESS CONNECTS TO YOUR FACTORY HARNESS.
Mar 15, 2010 | Kenwood Car Audio & Video
Im trying to install a phase linear cd player in a 1997 lumina and im not sure how to hook up the wires
If you go to your local parts suppy you can buy full wiring harness. It tell you what the wires are and it's about 20 to 30 bucks. But then you know that it's wired right
Sep 14, 2009 | 1997 Chevrolet Lumina
I have a honda im trying to hard wire it directley with the pioneer harness everything is connected right except there is no wire for my illumination wire to connect to. also im getting no power to th
you do not need to connect the illumination wire that is to dim the radio when the lights are turned on. make sure you have +12v on both the red and yellow wire and ground to the black wire. the yellow should be unswitched and the red should be a switched source.
May 20, 2009 | Pioneer DEH-1100 CD Player
Problem no sound
If your KENWOOD unit is experiencing audio problems (NO Audio), but do have audio when TUNER is selected as the source, you may have problems with your installation.
NOTE: If using an external amplifier or the unit was installed using a separately purchased wiring harness for your specific vehicle, please check the following
If Using an External Amplifier
The P.CONT or REMOTE terminal on the external amplifier requires a “turn on” signal from the stereo. This terminal should be connected to the BLUE/WHITE P.CONT wire on the Kenwood harness and not the solid BLUE ANT.CONT wire.
If Using a Vehicle Specific Harness
The vehicle has a factory installed amplifier and requires a “turn on” signal from the stereo. Make sure that the BLUE/WHITE P.CONT wire is connected to the vehicle specific harness and NOT the sold BLUE ANT.CONT wire.
The solid BLUE ANT. CONT wire is used to trigger a power antenna ONLY when the tuner is selected as the source. Using this wire to “turn on” an external amplifier or factory installed amplifier will only allow it to work when TUNER is selected. Please refer to your instruction manual for proper installation. If you are not completely comfortable with installing the unit yourself, we recommend that you seek assistance from a professional installer.
Apr 10, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
No Power to the unit
Hi perkyfridge,
You may have a problem with the faceplate connection not making good contact. Tell me what model Radio you have, that will help in determining what is wrong. Thank you.
Nov 22, 2007 | Pioneer DEH-P6400 CD Player
Pyle PLTDN71 Car Video Player Logo
155 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
