Question about GE Heating & Cooling
Hi, I have an air handler motor made by GE Commercial motors. I think the motor number is N656 S. It's a 1/2 HP, 1075 rpm motor to replace my existing air handler motor. I want to install it in my air handler, but it's wiring appears to be different than on the system I currently have. The current system has a purple wire hooked up, and I don't know what it's for. There is also a red and black wire which correspond to the yellow and black wires on this motor, but nothing to compare to the purple...
  • 3 more comments
  • wyattfisher Sep 05, 2009
    it is 1075 (says so on the side of the new motor). this is an older unit, so that may be part of the reason for the different rating.
    The old motor had black, red, and purple hooked up to the "power side", a green (ground) and two brown (to a capacitor. The red is the high speed.
    The new motor has a red, orange, 2 yellow, green (ground), blue, purple, black, and 3 brown. It was pulled from another unit, so it is already "wired up". Purple goes to one of the yellow (as shown on the side of the motor), one brown to the orange (as on the motor), red and blue hang out (I presume additional speeds), two browns to a capacitor (as shown on the motor side), which leaves the green for ground, the black (which replaces the current black), and the yellow (which replaces the current red).
    I just don't know what the purple was for. According to the wiring diagram in the air handler, purple is high voltage, black is high speed, and red (or yellow) requires a manual to determine what to do... I don't have a manual.
    I got it figured out... it took both motor wiring diagrams, and the air handler wiring diagram to figure out what was going on! It turns out that the red was NOT the power in (despite that being what the air handler said), it was the low speed setting. It was hooked up, even though it couldn't be used (single speed air handler). It took me almost 5 hours to get things figured out this morning, and get the new one installed, but it is up and running! Thanks to everyone for the help, I didn't realize that there would be 3 wiring diagrams involved, and each would have different wire colors identified. The key was seeing what the INTENT of the wires were, and connecting accordingly.
  • David Shaub May 11, 2010
    If you don't have the proper motor, don't put it in. 1075 doesn't sound right for the motor you described. Are you sure it isn't 1725? That's pretty much the industry standard.
  • 358 Answers
See where the purple wire is hooked up in the existing motor diagram (it could be the capacitor or a lower speed for the heater) and compared with the new one , and put it in the same place .But the easiest way to do it ,is to get the original replacement motor.
Posted on Sep 05, 2009
  • 582 Answers
THERE SHOULD BE OR THE MOTOR SHOULD HAVE COME WITH A SCHAMTIC SOME TIMES THE PURPLE WIRE IS FOR A CAPACITOR TO HELP START THE MOTOR OR COULD BE A TWO SPEED MOTOR. THE NOTOR SHOULD TELL YOU THIS
Testimonial: "Thanks for the help. Too many wiring diagrams is all I can say! I did get it figured out, thanks to the wiring diagrams on the motors. "
Rheem condenser fan motor
"the guy" added another start capacitor because the motor installed is actually better than spec. Your unit calls for 1/5 HP, 1050 RPM motor. The installed device is 25 rpm faster, and 1/4 HP.
The Rheem/Weather King/Corsaire/RUUD part number is 51-23055-11 (replaces many other Rheem/Corsaire/Weather King/RUUD Part #s including 51-21855-01)! It takes a 3 uf Capacitor rated at 370 volts. This Motor mouts with screws in the SIDE, instead of mounting studs coming out the back!!
Normal price for a generic motor w/ cap will be $125 or so, OEM part will be closer to 200. This is without the fan blade. Make sure you get the correct side mount studs.
This vintage unit is rated at only 10 SEER and is less energy efficient than a modern window air conditioner. Its days are numbered, and you are paying at least double every time it runs. Before you sink much money into this unit, please consider replacing it before it has a heart attack. Replacing it during the off season is cheaper anyway.
Please mark my answer down as helpful.
Jan 05, 2015 | Heating & Cooling
What causes the evaporator cooler motor not to re-start after the motor gets hot
I believe the motor may have an internal thermostat that prevents it from damaging itself.
Aug 31, 2014 | Emerson 1/2 HP 208-230V 1075 RPM PSC...
Payne air handler with possible GE X13 Failure
Check your dip switch settings on tonnage and your CFM per ton settings. Also make sure they wired the the low voltage for cooling to Y and not YLO if its a single stage compressor system.
Sep 23, 2012 | GE Carrier Bryant Payne 1/2 Hp 115 230v...
I HAVE A CARRIER AC FAN IS RUNNING REALLY SLOW!
is the motor hot to the touch? does it shut off while running?
You may have a bad running capacitor? for this motor
or you may have a 825 rpm motor that seems slow and is normal,compared to 1075 rpm?
Jun 12, 2010 | Goodman CKL36AR36 Air Conditioner
York Air Handler
you will need to look at front tag were you got the model number..it will tell you if it is a 1/3 hp or bigger,,also 48 y frame..230 v an rpm of motor like example 1100 rpm...hpoe this helps...if need more help ,just one call away...its free..michael doctor airr appl.repair ....843-384-8474...
Mar 27, 2010 | Heating & Cooling
Need a ge motor 1/3 hp 1725 rpm for a toledo commercial slicer or why does motor will not start until you spin shaft?
check motors bearings for oil ports try to lube first before replacing-common motor -appliance parts-online parts-catalog(grainger)or other hvac-plumbing-heating stores
Nov 04, 2009 | Kitchen Appliances - Others
Home ac compressor fan won't turn all the time.
your looking at $175-$225 for just the single phase motor depending where you purchase, I just replaced mine(identical unit) due to screaming dry bearings, if you replace it your self make sure to keep new wires tight along side of unit or fan will cut them if loose and its a fan- 5mfd/25mfd compressor@440volt cap
Sep 27, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
398 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
