GE Monogram ZDI15C Automatic Icemaker
Problem for GE Monogram ZDI15C Automatic Icemaker
Replacement of ice maker solenoid in door
By tnct on Sep 05, 2009
My in door ice maker solenoid needs to be replaced. I have the part (appliance guru), but I'm not sure how to access and remove the current solenoid. Is their a manual showing how to access the old part in trhe side by side freezer door?
Comments:
Sep 13, 2009
- I am looking to access the solenoid that is in the freezer door, in other words, I need to either open the icemaker control panel (crushed, cubes, water) from the exterior of the door or the interior of the door. The solenoid and plunger that I need to replace are located there. I'm just not sure if I have to take the entire stainless steel exterior cover off to access it, or if there is some easier way.
Solution #1
posted on Sep 05, 2009
Not Rated)
TheMobilian
Rank: Guru  GE Expert
Rating: 89%, 715 votes
Go behind the ice box and look for the water line going in. The water valve will be connected to the line. Be sure to shut off the water before attempting to do anythang.
Comments:
Was this helpful?
Yes
No
Popular Solutions for GE Monogram ZDI15C Automatic
Questions and Unsolved Problems for GE Monogram ZDI15C Automatic
Do you recommend GE Monogram ZDI15C Automatic Icemaker?
Answer
Answer
Ice maker is making ice. However, it is making a loud noice and the light turns off and on sort of... (More)
Answer
I have a GE Monogram refrigerator and the freezer side works fine but the fridge side is getting... (More)
Answer
There is mildew building up inside the unit. My company has the exact same model and it has no... (More)
Answer
Cleaned the unit, stopped making ice pump is running but still no ice. Is there a relay that picks... (More)
Answer
GE Monogram m/n ZD1S15CSSJ S/N VG930101 ICE CUTTER IS NOT STAYING HOT ENOUGH TO CREATE CUBES. THE... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
