My Samsung LNT3253H LCD TV has suddenly started changing its own settings (e.g. picture mode keeps switching to ''dynamic'' and the ''light effect'' keeps setting itself to ''always on''). Any thoughts on how to stop this?
    Novelist:
    Champion:
  • 210 Answers
Its in "Shop Mode".
Change your source to TV (analogue), now press menu>find "Plug and Play" and select it and runs through the setup and selct "Home" prompted and not "Shop".
That should sort its out, when its in shop mode its doesn't matter how many times you make changes, when you power it off it will go back to the original shop settings, this feature was built in to allow shops the have all show TV's to run at optimal settings and if a customer played about with the settings it would matter as they are reset again when the TV is switched off and the store staff don't have to go around resetting all the TV's at the end of the day.
Thanks
Posted on Sep 05, 2009
I notice my lcd brightness has reduce now this is 2 years old this problem remains same on Dynamic picture mode as well i have check this by connect to a pc and to a DVD using HDMI port...
hi,
First of all check the back light setting of your tv. you can see it on the picture setting menu.
Just check when you adjust the back light setting, is there is any change. if it changes and still not attaining the needed brightness level, then you have to check the back light inverter and the CCfL( cold cathode fluorescent lamp) used as back light. if there is no change in the black light, then the logic board or the inverter have some problem.
you have to check the inverter first is it getting the correct voltage from the power supply normally 24v.
if the voltage is ok , then u can do only one thing replace the inverter board to check whether the lamb have any problem. in normal case the inverter will become faulty. lamp fault is rare.
check all these. If you need further assistance fell free to contact me through fixya.
ok
Jan 18, 2011 | Samsung LA40A450 40 in. LCD TV
HLT6176SX/XAA TV ''MAKING DETAILED SETTINGS FOR PICTURE''
Your TV is on display mode!! The problems that you are having I had with my new TV.. Call Samsung or go online to their website and it will tell you exactly how to fix that small problem. As for the blue light, just go to setup and under light effect you will be able to choose when you want the light to come on.. I hope this is helpful...
Apr 07, 2009 | Samsung HLT6176S Television
Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Watty2c
Jan 17, 2009 | Samsung LN32A330 32 in. LCD TV
Problems with the picture mode on my samsung 46''
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
Jan 09, 2009 | Samsung LN46A550 LCD TV
Hi, I have new Samsung LCD TV LE37S8. I'm trying to set a picture to a movie mode, but it keeps changing to a dynamic mode after 15 minutes. How can I save my settings? Is it possible that is something...
if it's still in warranty, call 1-800-samsung and report it, other wise you need a main board or there could be a firmware upgrade on samsung web site that could fix it
Dec 28, 2008 | Televison & Video
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Poor picture
Dynamic mode will give you a brighter picture. The energy saving mode runs the lamp at a more efficient level that saves energy at the cost of a slightly darker picture. Based upon your description, I'd guess that the lamp is nearing the end of its useful life. Plan on changing the lamp soon. When you do so, place the set back to standard mode and energy saving.
Dan
May 30, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung LE46F8 picture setting
It sounds like your TV is in Shop Mode.
Shop mode is a set of picture parameters that have been optimized for a store showroom or display floor. Shop mode does not allow you save any picture settings such as brightness or contrast.
To get the TV out of Shop Mode press and hold the Menu button on the front panel for three seconds, the picture will blank momentarily then reappear with “Dynamic Mode” shown on the screen. At this point the picture parameters can be changed and saved.
Feb 16, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung 37
It sounds like your TV is set at Shop Mode. To veify that turn on your TV and press the info button on your remote, some info will be displayed, If Shop Mode appear please follow the next steps...
In order to change that mode turn on your tv, press the volume key (either one) on your front or side panel (Depends of the model you have) the volume bar will appear, once this happend press the menu key on the front or side panel and hold it for like 7 seconds, "Dynamic" symbol will appear at your screen this means that you are not longer at Shop mode. You can double check by pressing info button at your remote
Regards
Jan 14, 2008 | Samsung LN-T4665F 46 in. LCD Television
Can't use "plug&play" from TV menu
I can switch between shop mode & normal by holding down the menu key on the side of the screen, just press it till it changes.
Jan 07, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
574 people viewed this question
Top Televison & Video Experts
Electro Med Services...
