W1065 washer stops at the rinses setting on dial, and needs to be manually advanced.
  • 135 Answers
It always rinses with cold water. I would guess there is not enough cold water coming in and the unit shuts off while waiting for more cold water. Check the incoming cold water line and filter at the input connection.
Posted on Sep 05, 2009
Candy as108
IT has shorted out u will need to replace board
Aug 21, 2013 | Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Dial doesn't advance to next cycle
if u can advance it manually and it works u need a timer if not probably a lidswitch
Mar 27, 2009 | Maytag Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
