Question about LG X-Note LM50 Notebook
L G Wireless Problems. Comunication between netgear v5 and laptop
I Have the same problem, but when i switch my wireless router of it starts up ok. While my laptop is opperating and i switch my router on the same problem happens. It is a netgear v5 router. Othet wireless routers does not greate this problem. What do you suggest..... Any body please.
  • William Alequin May 11, 2010
    What's the problem? You don't mention here what is the problem. You said " I have the same problem".
  • 313 Answers
Some notebooks are not compatible with some routers. Netgear is not that user friendly. But it is not a bad router. you can do one or all of the following:
  1. Replace the router to a newer more user and compatible model. Upgrade to a newer "N" router.
  2. Download a network program to connect you. Network Magic is a good one. Cheap and works really well.
  3. Have a network pro come set it up properly and test your system.
Posted on Sep 08, 2009
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
I have a Netgear wireless router WGR614 v5 with the AC adapter of 120V-60Hz-16W. I've moved to Europe where the electricity is 220V. Can I use an AC adapter of 220V for this wireless router? Thanks a lot...
Yes, make sure you have a new power supply with the right voltage output, enough current (if the new power supply is rated for more current output, it will be OK), and the right plug with the right polarity.
Check your power supply, some will actually work with a wide range of voltage, some actually go from 100-250VAC. 50Hz-60Hz
Jan 05, 2011 | NetGear WGR614 Wireless Router
Hi my name is tam. I am using the Net gear WGR614 v5 and my laptop is using window 7. But i can't connect to internet via the wireless rounter netgear. The internet light was on but the wifi light is keep...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 23, 2010 | NetGear WGR614 Wireless Router
I have a THOMSON ST585v6sl with AOL running off
Well it may be possible, only if your wireless router supports WDS. Also, note that in DG834Gv3 , v4, v5 supports WDS. If you have v2 or v1 then it wont connet wirelss with your existing network.
Please reply if your existing wireless router has WDS and the version of the NETGEAR router so that I will provide you with the required steps to make it work wireless.
Jul 13, 2009 | NetGear DG834G Router
Problems connecting my laptop to wireless router
Make sure that you do the setup via cable, not through wireless!
If you change form WPA to WEP, the length of the key changes and you will have to provide this new key if you want to connect wireless to your router.
You can leave your laptop connected via cable and check if your wireless card can connect.
No, you don't have to reinstall everything again. Just plug in the cable, connect to your router (192.168.x.x) and check your wireless setup.
Dec 28, 2008 | NetGear WGR614 Wireless Router
NETGEAR WIRELESS
More details are needed here, do you have mac address filtering on and is your router using dhcp or fixed address for your computers?
Jan 17, 2008 | NetGear WGR614 Wireless Router
There is some prob with my Netgear USB
yes , first of all just tell me which windows operating system u r using on ur computer
Nov 20, 2007 | NetGear WG111 802.11g/b Wireless Adapter
Problems connecting to the internet with my wireless laptop
At the bottom right hand corner of your screen, you have a wireless conenction icon. right click and view available wireless network...if you see your network there. connect to that network, if secured, then call netgear to verfiy what is your network key. if it is unsecure then you can log on right away.
Oct 13, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
LG X-Note LM50 Notebook Logo
114 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
