Question about Samsung PCL6215R 62" Rear Projection Television
My convergence is fine but after professional replacement of the board there is a slight bowing and slanting of in-screen borders and some channels have a little distortion at the top of the screen. The pro made some adjustments using a code on the remote and improved it a bit but now that he's gone I can see that more adjustment is necessary. How can I continue to make adjustments without calling the pro back out? Thanks!
    Top Expert:
  • Samsung Master
  • 14,553 Answers
First: If the convergence board was replaced--the set may need a total adjustment---this is why most good techs replace the convergence chips and any bad parts instead--also costs less----Second: to enter the service mode (it is done with the set already turned on) should be Mute, 182 or Mute 183---if you get the convergence mode--7,8, 9 will select red, green, blue, 5 will stop the cursor from blinking and allow adjustment---with the cursor blinking 2,8, 4, 6 will allow you to navigate---depending on the remote used--the P mode button will take you across the screen in a series of steps--the remote I use for this has a button on it marked data save--this saves the adjustments. Your remote may have it or a different button for this.
Understand---if you get into the convergence mode---Green determines if the geometry of the picture is straight---red and blue are adjusted to it---to align the green you need to call the convergence mode up and then cover the lens for the red and blue---leaves you with a green grid---then you need to select green and wherever the grid is not straight adjust it--once you get it straight you need to uncover the red and adjust it to the green, and then the blue to the green---green alignment determines if the picture is straight---It sounds like this guy did not try to get the green straight and just adjusted the red and blue to whatever the green was.
My point here is if you paid money for this repair--either he aligns it straight or you should get your money back----GREEN never needs to be adjusted unless the dcu(digital convergence unit that stores the adjustments) has been replaced or the Convergence module has been replaced---I bet if the original convergence module was repaired(chips replaced etc) and installed you would not have this problem.
If the guy replaced the DCU then GREEN must be fully adjusted for a straight picture FIRST! then red and blue adjusted to it.
It is not easy or quick to Adjust the green--maybe he just wanted to get out the door?
I do this here for free so if this has helped you take a minute and give me a vote here.
If you have any questions or need help reply to this post here.
SD TECH
Posted on Sep 05, 2009
My screen has a slight bow shape
its probably convergence -
here is my tutorial
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
rca hint at the bottom.. it probably needs a convergence power board, easy install.. 4 screws and 2 plugs(wires)
Jun 18, 2010 | RCA P52960 52" Rear Projection Television
My 57hx81 has a slight concave bow in the middle top to bottom
Sounds like a problem in the vertical sweep circuit. Check voltages to your convergence ICs. If they are  not to spec then look for bad fuses and capacitors on the power board. These will throw off the DC voltage to the convergence chips causing the bow effect. I've had a single bad pico fuse ($1) cause this symptom.
Dec 06, 2009 | Toshiba 57HX81 57" Rear Projection...
Borders bowed inward,blurred red,blue, & green
the next time it is not working go into the customer menu with remote and call up the convergence grid and look---there---if convergence is way off and or comes and goes---this set uses 2 Stk-392-570 ic's and it is quite common to see them become intermittant.
Aug 03, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Problem after replacing convergence board
Yes, you do need to set up the convergence in order to get the picture geometry correct. the antenna and maybe some other settings will need to be restored through the appropriate user interface screens. You will need your owners manual for a guide.
Jul 12, 2009 | Samsung HCM4215W 42" Rear Projection...
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Kp-46wt500 shadow and slanted images with rainbow colors
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 04, 2009 | Sony KP-46WT500 46" Rear Projection...
Mistubishi Convergence/video display problem
also check resistor values on the chips and resolder the tuner as this can cause problems as they heat up , then replace any electrolitic capacitors in the video circuts selector ic
i will be back to see what you get
electech
Oct 26, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Pt-47wx49e convergence problem
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
Oct 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Sony KP-43T90 no picture high voltage seems to work
The convergence board or one of the deflection yokes has some failures. This may be a little expensive to service.
Jerry G.
Nov 08, 2007 | Sony KP-43T90 43" Rear Projection...
Samsung PCL6215R 62" Rear Projection Television Logo
177 people viewed this question
Henry  Thomas
Henry Thomas
