Question about Rockford Fosgate Punch 800a2 Car Audio Amplifier
Rockford Fosgate punch protection light
I touched the postive wire to the case on my amp it gave a little spark nothing major now the protection light wont go out i dont know the model off the top of my head but the number is 600 some thing im not sure if its bridagble any help would be great
  • 733 Answers
Power it off, then on...check you're fuses. unplug the car battery and try again. good luck.
Posted on Sep 05, 2009
Hi, I was trying to replace my subs and during the process, the positive wire touched the negative wire and my amp turned off. I have the Punch 801s 2400 watt amp. Is there a way to reset it? I'm assuming...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping. A thumbs up would be greatly appreciated if this answer is helpful to you. GOD BLESS YOU.
Oct 17, 2013 | Rockford Fosgate Punch 801S Car Audio...
My rockford fosgate T1 amp blew a fuse and now protection is on
Chances are that more than a fuse went. I would follow (internally) the path of the wires from the speaker you mentioned - inside the amp. This should bring you out to the main amp. I think you will find that whatever powers that channel is faulty.
Apr 10, 2013 | Rockford Fosgate FAP T1 Amplifier
Protect light stays on and nothing else
Your amp is fryed it happened to me. Pull the covers off so you can see the mother board and Then try connect all wires. But don't connect the light up display. Good luck. Im gets a bit Hot now and only two ch work
Nov 05, 2011 | Rockford Fosgate Punch P4004 Car Audio...
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Audio cutting in and out protect light turning on Rockford fosgate p4004
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping. Try adding a capa A thumbs up would be greatly appreciated if this answer is helpful to you. audio-cutting-in-out-protect-light-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Jun 20, 2010 | Rockford Fosgate Punch P4004 Car Audio...
I'm looking for a wiring manual for a punch 150 amp
Follow this link to the downloads page for Rockford Fosgate, you can choose the correct manual there.
LINK
Sep 25, 2009 | Rockford Fosgate Punch 150a2 Car Audio...
401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
try hooking the remote wire to a rem wire on the back of stereo. post and let me know results
May 30, 2009 | Rockford Fosgate Punch 401S Car Audio...
Rockford Punch 550.2 amp wont play
The amp is blown and need to be repaired.
You can contact Rockford direct to find a repair dealer.
Apr 16, 2008 | Rockford Fosgate Punch P550.2 2-Channel...
Rockford Fosgate Punch 360.2
If the wires were touching then the amp overworked itself into a early grave..What happends when they touch is the amp goes from seeing a 4 ohm load to seeing a 0 ohm load. You can imagine why this would be bad for a amp...usually the amp should shut off to protect from damage and I would assume that Rockford would. Right now im having a similar problem..I suggest your call rockford and ask to talk to a technical advisor ( the name escapes me) and ask him what he thinks.
Mar 17, 2007 | Rockford Fosgate Power 360.2 Car Audio...
Car Audio & Video Logo
215 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
