Question about Lexmark X3550 All-In-One Printer
SCANNING UNIT OF MY PRINTER MULFUNCTIONS
The scanner unit of my Lexmark X3580 is making a continuous clicking sound so it is unable to scan and/or make copies.
I have noticed that, the toothed belt which moves on the gear to transport the scanning light is the one producing the noise at the extreme right where it comes into contact with the gear. Please help me resolve this problem.
  • Bright Dey
    Bright Dey Sep 05, 2009
    Actually there is no latch or lock anywhere, besides, I've been using it without this problem until just yesterday when the problem started.Thanks however for your concern but this was not very helpful. I'll be glad if you can suggest something else.
  • Bright Dey
    Thanks Oloo for your suggested solutions the second time round but I don't seem to get it-I mean the information you provided. Please could you explain further for me.
    I have detected that the four cables(Yellow, Brown, Orange and Black) which connect the Motor which controls the gear and belt to the circuitry board might be causing the problem. I therefore think that it is more of a hardware issue. Well but you are the technical man. I'm just offering more information. Please let me hear from you.
  • 58 Answers
Well, It could be actually broken, in which case I would open it up and look for the offending part.
It may be as little a loose screw or as bad as a broken something.
Or, it could be the software trying to calibrate for use.
If certain parts are dirty the scanner won't properly initialize.
Clean the glass, the bulb and any mirrors.
Or, it could be toast.
Posted on Sep 05, 2009
  • oloo Sep 05, 2009
    Hi again..
    This is a modern MFC with a mixed reputation. It did not take long to discover some serious complaints about the Scanner drivers See the first review here at Amazon bu user S.Rega: http://tinyurl.com/neqr2b
    So this could be getting into the "you get what you pay for" department.
    A decent new scanner from a reliable manufacturer is usually more expensive than the whole Printer/Copier/Fax/Scanner Lexmark X3550.
    So, If you can't fix it by jiggling the wire you mentioned or updating the Driver software, or cleaning the components, or getting it replaced under warranty --- then it is probably history except for the printing function. It can probably also fax documents from your PC.
  • 58 Answers
See if there is a lock or latch somewhere ( usually on the rear ) holding the belt.
Some manufacturers have these to prevent damage during shipping.
My lexmark s605 does not work
If you tried to reinstall, then the problem is not coming from your computer but the unit itself. If it does not go through the motion of scanning, then it is a problem in the power to the motor which is most likely "fried."
Aug 27, 2012 | Lexmark "interact s605 wireless all-in-one...
Lexmark X4550 scanning unit chatters constantly after power up
The belt is slipping either because it is loose or because the lock is engaged.
Take care!
damnor01
Jun 10, 2012 | Lexmark X4550 Multifunction Wireless Color...
Use of Scanner
On this model there is a SCAN in black and white or color buttons but you need to have something on the glass to scan. Once it scans it prints!!!
Now lexmark software if installed comes with a program to scan with. you need to check under your prgrams folder under lexmark for the scanning software that was installed with the print driver.
If you open the lid and you do not see the white light chances are your scanner has and needs a bulb inside and at the point to install one of these you might want to concider a new printer.
Please be considerate and leave your feedback and comments and ratings before you leave, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 30, 2010 | Lexmark X2500 All-In-One Printer
How to load ink catritridge #4&5
plz follow the steps below:
Step 1 Locate the "On" button located on the top right side of the Lexmark 2600 Series Printer Scanner. Turn the unit on by pressing and releasing the "On" button one time.
  • Step 2 Raise the scanner unit until it locks into place. Allow the print cartridge carrier to move to the loading position. Wait for the print cartridge carrier to stop moving.
  • Step 3 Locate the color print cartridge in the carrier on the right. Release the empty color print cartridge by pressing down on the cartridge carrier latch. Raise the cartridge carrier lid. Remove the empty color cartridge by pulling it straight up. Place the empty cartridge in the plastic bag and set aside for recycling.
  • Step 4 Remove the new color cartridge from its packaging. Remove the protective tape from the nozzle and connector on the back and bottom of the color cartridge. Dispose of the protective tape.
  • Step 5 Install the new color cartridge into the right cartridge carrier slot. Close the cartridge carrier lid. Press down on the cartridge carrier lid until it clicks into place.
  • Step 6 Raise the scanning unit slightly. Release the scanning unit support. Close the scanning unit.
  • If u find this post helpful, then plz vote it.
    Thanks
    Apr 27, 2010 | Lexmark X2600 InkJet Printer
    Unit makes a clicking sound at end of the power-up sequence
    Sounds like the scanning mirror might be locked - during shipping, the mirror is locked to prevent damage. Look around the back or the underside of the unit and look for a slider with a lock/unlock picture on it. Slide it to unlock and the mirror should be free to move.
    Nov 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    6150 scans leave a line down the scanned image
    There is probably a speck of dust on the scanning unit. You can unlatch the glass scanner table and, with the unit powered down and the cord unconnected, gently pull the scanning unit out (or you can start a scan and power down the unit when the scanning unit is in the middle of the table). Opening the scanner table will void your warranty!
    Examine carefully the glass "window" of the scanner in the area corresponding to the dark line using an angled light and see if you can spot the dust. You can clean the window glass with a lint-free cloth dampened with alcohol. Do not press hard on the scanning unit since the mechanism is quite delicate. Afterwards, carefully replace and latch back the glass table.
    If the dark line does not go away, you might have a faulty scanner, but that's unlikely.
    Oct 27, 2009 | Lexmark X6150 All-In-One InkJet Printer
    I have a lexmark 6150 i just got a computer with windows vista, i loaded the drivers and the printer works but the scanner does not
    The Windows Vista x64 drivers available on the Lexmark website do not contain the All-In-One Center. They are minimum drivers. Although the scan drivers are shipped with the web package, they cannot be used by the All-In-One Center since it is not included. Please use Windows Scanners and Cameras or Photo Gallery for Scanning.
    Please follow the steps given below to perform the WIA scanning:
    1. Click on "Start," and "Windows photo gallery."
    2. Under "Windows photo gallery" click on "File" and " Import from camera and scanner."
    3. Select the "Lexmark X6150 printer" and click on the import button.
    4. To begin the scanning process, click "Scan Now."
    Oct 18, 2009 | Lexmark X6170 All-In-One InkJet Printer
    SCANNING
    Load the text document face down on the scanner glass.
    Open the Lexmark Imaging Studio.
    Click the Scan & Edit Text (OCR) button (shown below).
    The All-In-One Center appears with the Scanning & Copying tab expanded.Click Preview Now in the upper right corner of the All-In-One Center. An image of the scanned document appears in the preview section.
    Click and drag the box with the dotted lines to select a specific area of the preview image to scan.From the Select your text editor: drop-down menu, select a word-processing or text-editing program.Click Send Now.
    Jun 18, 2008 | Lexmark All-in-One Printer with PictBridge
    Scanner won't scan
    Right Click on My Computer/Computer if Vista........ Click on Properties then click on Hardware click on Device Manager...... On that list u will see the Printer Name with an exclamation Mark........ Right Click on that click on update Drivers...... Insert the CD to the drive....... Select Browse My Computer for Driver software..... Click on Browse and then Double Click on Computer go to Lexmark X*****.......... Double click on Drivers and then click on scan and then click ok........ Now click next it will say the hardware is ready to use then u can just click on finish and scan..... Thanku
    Apr 15, 2008 | Lexmark X8350 All-In-One InkJet Printer
    HP LJ 3020
    The scanning unit is faulty, u may trying cleaning the scan unit ,else it needs replacement.
    Happy printing
    Omnipresent
    Oct 17, 2007 | HP LJ 3020 All-In-One Printer / Scanner /...
    Lexmark X3550 All-In-One Printer Logo
    117 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
