Question about Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Side out of image
My canon 28-135 .lens has side out focus problem.the right side of the image is out of focus......
    Brigadier General:
  • 3,006 Answers
I'm assuming in what follows that you've tried other lenses and only get the problem with this one lens. If you haven't, then it's essential to do this first unless the lens is obviously the problem. If it happens with other lenses then you have a damaged image sensor mounting within the camera body which will need professional attention.
This is a common problem on this particular lens. Normally it's due to the front element of the lens being slightly skewed on the lens barrel and most commonly occurs after the lens has been dropped.
Turn your lens to manual focus and focus to the shortest distance. Set the lens upright on a table and carefully view all around, if the problem is the front element it will lean slightly to one side like a miniature leaning tower of Pisa. If it doesn't, then check again with greater precision using a ruler to measure the distance s between the lens barrel and the focussing ring and a number of opposite points around the circumference. If they're anything but identical then the lens is skewed. If they are identical then the skewed element is buried deep inside the lens and will need professional repair as it's most likely a fault with the moving element used for image stabilisation.
If the tests confirm that the front element is skewed then if you're really careful and lucky you can often jiggle the front element using a firm twisting action back into place. It does take a bit of judiciously applied brute force and if unsuccessful you can make the problem worse, but either way if you don't try then the lens needs professional repair and new internal parts.
I've had this problem on about one of these lenses every month or so for the last year. The brute force repair works in about half the lenses I try it on and normally lasts. On the others a strip down repair usually shows the same range of broken/worn parts as I find on those lenses which clearly are too far gone to attempt the brute force method.
The difference is cost: the brute force repair costs nothing. The proper repair is often economically unviable as it often costs 50% to 70% of the cost of a brand new lens with a warranty.
Posted on Sep 05, 2009
I have a Cannon EOS Rebel xsi SLR camera. When I look through the viewfinder the image is blurred. IT worked fine the last time I used it, but this time it is blurred and I haven;t been able to correct...
Two possible situations. It might be that the lens focusing system isn't working. Try focusing by hand (turn the lens manually) If the image moves through a point of sharp focus, then you have a lens or focus motor problem.
More likely, you have improperly adjusted the diopter. There is a small, circular wheel on the right side of the viewfinder, toward the top corner. It is sometimes covered by the rubber viewfinder hood so you might not notice it. This adjusts the diopter correction in the viewfinder and if it's set wrong, nothing will ever look in focus. The pictures would be fine, but since the diopter is a correction for your eyesight, the viewfinder will be out of focus.
Feb 05, 2011 | Canon Cameras
Error 99 and jerky fixation of focus between 17 and approxinately 30 mm works perfectly at zoom lengths beyond this with normal rapid fix of focus and records image normally. the error and failure to...
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
For the jerky focusing ring, you need to get the lens serviced by an authorized service center.
Aug 28, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
I bought the 10x25 camera binoculars and only one lens will focus using the center dial. Its almost like the other one needs to be focused at the eye piece itself. The pictures are not clear and are...
It is common for binoculars to have one independently focusable eyepiece.  If one eyepiece can be rotated, then that is the case.
If that is the case, focus through the one that DOES NOT rotate using the center control until you get a sharp image on that side.  Then rotate the eyepiece on the blurry side until the blurry side is sharp.  If you succeed at this, from henceforth the center control will focus both eyes adequately
Aug 11, 2010 | Sharper Image Optics
Canon SD 750 all images blurry on left side
service the focousing unit of the lens,if needs replace the unit.
Apr 02, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I bought a Canon XSI for christmas. I owned a Rebel and have a 70-300mm IS USM lens which has been working ok. On the XSI all photos are blurry. My 28-135 lens works ok on the XSI.What could cause this...
Good Afternoon,
if I'm to understand your problem when you transferred the 28 to 135 lands from your rebel to your new XSI you began getting out of focus pictures.First make sure that your diopter is set properly on the camera to do this remove the lens turn the camera meter on and adjust your rear diopter control so that all the numbers in the finder are sharp to you then replace the lens. Next I would test the quality of the autofocus system. To do this place a magazine page with large bold lettering flat against the wall. Then aim the camera at this page at a 45° angle using just the center focus point.select a word on that page. Make sure your camera is in the AV mode with no flash and set your f-stop to 4.5. When you take this image you're going to look at it on the computer what you should see is the focus point that you used should be very sharp everything trailing off the backside of that focus point should be fuzzy and everything to the front side of that focus point should be fuzzy.If you find the image is sharper to the front side of your focus point you're getting what they call front focusing. If your image is sharper to the backside of your focus point you're getting what they call rear focusing. These issues can be addressed usually in the software set up on the camera. Again to recap you'll need a flat piece of artwork that you can put on the wall you need to position your camera 45° from that artwork set your f-stop to wide-open centerpoint focus only. I would be more than happy to answer any further questions directly contact me@Dave@advancecamera.com
Jan 11, 2010 | Canon Cameras
My Canon PowerShot SD1000 won't focus. Most
Sounds like you may not be in "Auto" mode. Press the "Func/Set" button, then press Right or Left to select the "Auto" mode.
Nov 01, 2009 | Canon Powershot A1000IS 10MP Digital...
Focus hutning with Canon EF-S 17-85mm f/4-5.6 Image Stabilized
I had this problem too, then my camera started getting Error 99 (there is some problem) and not working.
If you look at this website and follow the steps under Update 2
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
I think you will fix your problem. The connections between lens and camera probably have a little dust in them, use a soft rubber eraser to clean them. Make sure no dust or pieces fall into the camera or lens when cleaning!
Jul 28, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
The images are not crisp - as if not fully in focus
I am having the same problem. I bought a Tamron zoom lens as an add on. This lens costs more than the camera and yet images are not as sharp as i would expect from such a highly touted camera. My Kodak Z740 point and shoot gives sharper prints. This is very frustrating. I bought Rebel for Dummies and still am having the same problem. Very frustrating
Jul 21, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Autofocus on my Canon 28-135mm f/3.5-5.6 EF IS fails
Hello. First, check the contacts on the lens mount--you're looking for bent pins, oxidized(odd-colored) metal, damaged contact points, etc. The camera must communicate reliably with the internal circuitry of the lens unit. If there is any dirt, moisture, intermittent contact going on, the sensitive focusing electronics will be effectively blinded. If all is fine with the contacts, then the problem lies with the circuits in the lens that provide critical focusing data to the camera. Movement of certain parts causes electrical changes to occur at a calibrated rate--if the camera loses connection, it can't tell if the lens is actually adjusting. You'll have to send the lens in for repair--http://www.usa.canon.com/consumer/controller?act=SupportIndexAct. This address should get you started.--Hope I helped!---Rick
Mar 19, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
My camera lense will not focus automatically or manually.
There is no battery in the lens.  The lens receives power from the camera. Whether or not the lens is getting power, though, you should be able to focus manually.
When you say you can't focus manually, do you mean that you can't turn the focusing ring on the lens, or that when you turn the ring the image does not come into focus?
If you decide the lens needs to be repaired, I recommend sending it to Canon.  You can go to their website (canonusa.com if you're in the US), click on support, and follow the links.
Dec 20, 2008 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens Logo
121 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
