Question about Garden
Instructions to replace starter on JD RX75 lawn mower engine
I am looking for detailed instructions to install the starter back onto the engine of my John Deere RX75 lawn mower. It was removed by another mechanic and rebuilt at an alternator/starter shop. The tag was lost, so I am not 100% sure that it is the correct starter.
Thanks for your help!
  • honeysuck824 Sep 05, 2009
    I should have been more specific. There is not enough clearance to slide the starter gear into contact with the flywheel gear. I have removed the 2 studs and wonder what to remove next? It seems like the starter is too long - the bottom hits the oil drain area of the housing before the top will slide in.
    thanks
    The problem is not the spacing of the bolt holes - I can't even get the starter into position on the engine. Is there some easy way to remove the sheet metal shroud on the engine that covers the starter gear?
    thanks
    p.s. would a picture help - how do I upload a picture?
    Problem Solver:
  • 10 Answers
DID YOU TAKE THE TOP COVER OFF THE MOTOR? AND THERE IS ONLY ONE WAY THE STARTER GOES OTHERWISE IT HITS THE SIDE OF THE ENGINE.. i REPLACED MY STARTER FEW MONTHS AGO.. tHE STARTER WIRE HAS TO BE ON THE OUTSIDE TOWARDS THE OUTSIDE BODY....
Posted on May 02, 2012
  • 1,869 Answers
AM102628 STARTER MOTOR insert starter place bolts into lug holes in starter thread into matching holes on the engine (if bolt is too long and, bottoms out try another bolt
attach wires to the solenoid you're done
torque the bolts to 35 foot lbs.
Posted on Sep 05, 2009
  • Jim Goldsmith
    Jim Goldsmith Sep 05, 2009
    I believe you have the jdrx95 starter (it's a little longer)
    measure the distance from bolthole to bolt hole on the starter and, the starter engine mount if they are not the same you have the wrong starter. if they are the same length and, width you have the right starter and, you will have to spin it into place.
    do not forget you may need to shim the starter gear away from the engine flywheel to get proper clearance for the pinion starter gear to smoothly mesh with the flywheel.
  • Jim Goldsmith
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
John deere srx 75 starting with key doesn't work why
if u wiggle the gear shift lever , holding key to start does it work ? if so then u need a new or adjustment neutral safety switch (also key does have running deere on it ?) as non factory keys don't work to well either
also this machine is listed on jd tech site as one that has been noted for an "starting improvement kit " part # - AM107421 jd has made it plain that they know it doenst start so well ,so they have released this kit to install that improves its starting
May 25, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
What type of oil does it use? John Deere RX75
some use straight 30 some 5-30 others 10-30 jd has their own oil as well the following chart showes the type
May 12, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
How do you change the drive belt on a john deere d110 riding lawn mower?
You can look at the manuel that came with the mower or if you did not get one, go to the JD mower web site and look up you model and download the needed documentation. If that is not possible contact the local JD mower dealer and get a copy of the mower deck docs and look at the instructions for belt replacement.
Jul 31, 2014 | John Deere Riding Lawn Mower. D110 42 in....
JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
Mar 31, 2012 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I have a John Deere rx75. The mower deck seems to be too low when I set it at the highest position. I have no idea how to do that or to level the deck. Please help. The lawn is cutting uneven and its...
find someone who can read and use the internet
go to www.google.com
search for john deere lawn tractors
go to the john deere website and click around under "support" until you find the manuals
download a manual for your model,l but they are all about the same
have the person who can read, read you the part in the manual about adjusting the deck height and how to level it.
there you go, bob's your uncle.
Sep 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I am having difficulty getting the nut off to change the oil on my JD Rx75. Any suggestions or could you explain the procedure.
If your mower is a GX 75 it has a brass square nut on the back of the engine.
Use a open end wrench and turn a few turns and it will open a valve to drain the oil.You can unscrew it until it stops turning.Dont over do it.
Their is a hose that attach's to the valve so you can drain it to a bucket or drain pan.
So you are just turning a valve, if it doesn't drain look for dirt or stuff plugging the valve.
May 02, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Petrol Lawn Mower starter cord and spring problem
remove the shroud Ithe cover over the flywheel) and remove the old rope. now rewind the spring in the opposite direction of the string hole until the spring is tight. Then clamp it down so i won't unwind and reinstall a new rope (the same size) into the notch in the pully and tye a knot. then release the clamp and let the cord wind onto the pully(make sure the cord gose through the hole in the shroud. then replace the handle and reinstall the shroud back onto the engine..Good Luck
Apr 04, 2010 | Garden
RX75 JOHN DEERE. WILL NOT OPERATE BY IGNITION SWITCH, BUT WILL TURN OVER WHEN CROSSED AT SELENOID
HAVE YOU CHECKED ALL THE SAFTEYS ON THE RX75 IF SO THERE COULD BE AN INLINE FUSE FROM THE SWITCH TO THE STARTER
Sep 16, 2009 | Garden
Change oil in riding lawn mower
look at the side of the engine down low. There should be a pipe plug screwed in that has a square head. Put a drain pan under the area and remove this plug and the oil will drain out. It's best if the engine is warm. You should get 1 1/2 quarts of oil out of it. Let it drain for about 5 minutes and then re-install the pipe plug. Add 1 1/2 quarts of 30W oil and then cut the grass !
Aug 27, 2009 | Garden
Garden Logo
1,073 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
