Question about Canon PowerShot S1 IS Digital Camera
Cannot see object through the lens. earlier could see only violet horizontal stripes in place of object. I can view the photos stored.
  • Canon Master
  • 4,738 Answers
Test
Posted on Sep 05, 2009
  • CameraR
    CameraR Sep 05, 2009
    This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
    Applicable cameras include:
    A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Canon t6s has a thick black diagonal "object" in all photos
Could be a lens hood or some other attachment masking the field of view, but that would be obvious.
Otherwise, in a dust-free environment, detach the lens, use a bulb-type air-duster brush to blow the interior, as the CDS sensor may have something blocking its view.
Nov 17, 2017 | The Optics
HORIZONTAL STRIPES ON PICTURE
Hi!
Turn on the camera
Pull the lens at maximum zoom
Turn off the flash!!!!!!!!!!!!!!!!!!!!!
Shoot the picture - look into the lens.
If no motion picture shutters in the lens:
1. Faulty flex cable shutter
2. Faulty valve solenoids
etc.
Requires repair of the shutter assembly in the lens
If you saw the shutter and blurry pictures as paint - matrix defective - Replace the camera matrix.
Dec 08, 2013 | FUJIFILM Finepix S2100HD Digital Camera
Fuji finepix 5600 white stripes
When you say 'played back', do you mean viewed on the camera screen, or after downloading to your computer ? If the latter, it could be to do with the software you are using - try FastStone.
Apr 18, 2017 | Fuji FinePix S5200 / S5600 Digital Camera
How to use meade telescope 60AZ-T ?
The whole unit is a "scope". What you mean is the objective lens to the eyepiece lens. Usually the wide end is pointed at the object or scantily clad person that you wish to view, and your eye is placed near the small diameter lens at the other end. If you have it reversed, it will work as a microscope.
May 06, 2012 | Meade Optics
Need connection details for Blaupunkt Bamberg SQR 05
It should follow the usual practice:
White and white with black stripe- Left front.
Gray and gray with white stripe Right front.
Blue goes to the power antenna lead
Yellow is the data store and should connect to a point that is always hot from the Battery "+" and not interupted by the ignition switch It should have a 3 amp fuse.
Red is the main power and should be wired to a point that foes get interupted by ignition switch- such as existing radio It should be protected by 8 amp fuse.
Black is ground (-)
Orange is dimable illumination- wire to a dash light
The black wire with an 1/8 jack end is for portable devices to plug into.
Green and green with black stripe Left rear speaker
Violet and violet with black stripe is right rear speaker.
Alternately you can opt for the red and white RCA terminated leads to plug into another amp's input for rear speakers,
Mar 30, 2012 | Blaupunkt Car Audio & Video
Jvc kd-hdr1
Most wiring now is standard colors....red=ignition(goes to a switched power source...Yellow=battery...goes to a hot all the time(even with key off)...black=ground...white=left front speaker positive...white w/blk stripe=left front speaker negative...gray=right front spkr +...gray/ blk=right front spkr - ...green=rear left +....green/blk rear left - ...violet=right rear +...violet/blk= right rear - ...light blue or blue with a stripe is the remote turn on lead either for an amplifier or power antenna...some radios have an orange/ with white stripe that connects to your parking light dimmer circuit to dim the radio light with the dash lights....and then you should have the antenna plug and possibly rca outputs that go to an external amp
Feb 26, 2012 | JVC KD-HDR1 CD Player
I need wiring diagram for DEH 2100 pioneer
Wiring information is as follows:Yellow = +12V ConstantRed = +12V AccessoryBlack = Ground (Chassis)Blue/white stripe = Remote amp turn-on/Power antennaWhite = Left Front +White/black stripe = Left Front -Gray = Right Front +Gray/black stripe = Right Front -Green = Left Rear +green/black stripe = Left Rear -Violet = Right Rear +Violet/black stripe = Right Rear -
Here is a link to a website that has a PDF document for the Pioneer Owner's Manual:
http://www.manualowl.com/m/Pioneer/DEH-2100IB/Manual/56355
In this, you should find the information you are looking for. I hope this was helpful.
Aug 27, 2011 | Pioneer DEH-2100 CD Player
My wonderful exilim ex-s770 camera when switched on is now fuzzy through the view finder and when the photo is taken
1- Easy: could it be the lens needs cleaning?
2- Difficult Hardware problems:
-Do you see striped unclear violet marks all over the image? If so it could be the CCD sensor has become degraded
-Could be the lens is misaligned out of position due to a blow or fall?
Please rate this Fixya answer
Mar 05, 2011 | Casio Exilim EX-S500 Digital Camera
Flashing horizontal stripes on screen while shooting
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 18, 2007 | Canon PowerShot A70 Digital Camera
Blank stripes on page left to right
If the blank stripes go up and down the page (vertical) then it sounds like the laser lens has simply got toner on it. remove the toner and photo conductor units. Look for the glass panel that covers the laser lens and simply wipe it off with a cloth. Some machines incorporate a lens wiping pad that can clean the lens without taking out the parts. I can not remember if the 1710 does or not.
Sep 06, 2007 | Samsung ML 1710 Laser Printer
Canon PowerShot S1 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
