Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
Dishwasher PLD 3465 REC I cannot reset the display panel. I took the kickplate off which was supposed to have the code for the reset but it had nothing related to reseting the display panel. It is stuck on 94 min clean time. What is the code to reset? There is nothing in the Use & Care manual that tells you how to reset.
  • 135 Answers
Putting the unit into service mode will reset the the display. Look at the instructions behind the front panel. If the unit fills and does not wash, the wash motor may not be working.
Posted on Sep 05, 2009
SOURCE:
How do I install miele dishwasher toe kick?
Dishwasher Kickplate (part #00446633) - How To Replace ...
? 2:07
www.youtube.com/watch?v=8GJnHVlAx5Q
Mar 5, 2014 - Uploaded by AppliancePartsPros
Buy the new Dishwasher Kickplate 00446633 http://www.appliancepartspros.com/bosch-kickplate-446633 ...
Sep 26, 2015 | Miele Dishwashers
Have an error code 01 on my electrolux dishwasher
Good Morning Friend, I am happy to assist you!
Typically error code ER01 indicates that a water leak has been detected under the tub of your Electrolux dishwasher. Your dishwasher may possibly need a hydraulic kit. Try unplugging your dishwasher or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and turn on your appliance. If the error code continues to display, then I recommend contacting a professional to make a precise diagnosis. Best regards! - Z
Jul 20, 2014 | Electrolux Dishwashers
Remove kick plate
Tip the unit back and put your hand under each side in turn underneath, the kickplate is held on via clips near each front foot (the retainer lug is part of the kickplate) this will release it. To reinstall offer the kickplate up under the door panel and give the bottom a push to relocate the clips.
Mar 19, 2013 | Bosch SMS68M02AU Dishwasher
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
How do I read the fault codes for my kuds30ix dishwasher
Take off the bottom kickplate, where the water and electrical hook up. Somewhere on the back of that kickplate or under the machine by usually by the inlet valve there should be a sheet with trouble codes and troubleshooting procedures on it.
Jan 30, 2011 | Dishwashers
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
PS3 display problem for multiple TVs
try to do a simple reset it will reset your video settings just turn it off then hold the power button then KEEP HOLDING until it beeps 2 times then it should come up note: it will not delete any of your data
Mar 04, 2009 | Mitsubishi WD62627 62" HDTV
Dishwasher Reset / Diagnostics
Unscrew and remove the kickplate at the very bottom of the dishwasher. The tech sheet with the diagnostic code should be attached to the back of it.  If not, due a websearch and you should be able to find the info on yahoo or google.
Jan 05, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
1,221 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
