Question about Lanzar OPTI1222D Car Subwoofer
My car sub wont turn on checked all the wires and they were fine and the sub was working fine in my other car right before i changed it?help please
  • 53 Answers
Check the leads on the sub itself. sometimes the leads from the plugs to the coils come undone.
Posted on Sep 05, 2009
Subs wont turn on
make sure there is correct wattage with the subwoofers and the power supply
Dec 07, 2013 | Sony Xplod XM-554ZR Car Audio Amplifier
Hi ive got a alpine mrp-m1000 it lights up no sound was woking fine in the car didnt use car for 3 months then i wouldnt work all wires are fine and so is the sub please help
If your not getting any sound make sure the sub input is in the right spot on you radio. if not check the speaker wires on your harness
Feb 14, 2010 | Alpine MRP-M1000 Car Audio Amplifier
One of my subs doesnt work why?
bad conection,blown sub,try wires from the one that works on the one that doesnot if it works then the wiring is broken somwhere.
Dec 28, 2009 | Car Audio & Video
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
My amp wont power both subs the same
you most likely mess up you wiring... im not sure what ohm resistance your subs are, but if its 2ohm or 4ohm you wire straight foreward one sub all positive wires to left positive, all negitive to left negitive, and the same with sub 2 to the right terminal. BUT if your subs are 8ohm then wire it with all positives from both subs to LEFT positive and wire all negitive wires to RIGHT negitive... and see if that helps and good luck!
Jan 12, 2009 | Pioneer TS-SWX310 Car Subwoofer
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
What could be wrong???????
The only thing left is the wiring, and or connectors from what you are describing.
You can try another amp and another set of speakers on the same wiring to see if they work. If not, the only thing you have left is the wiring and connectors (if connectors are used).
This suggestion is valid providing that substitution equipment is not defective.
Jerry G.
May 01, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Speaker trouble
MAKE SURE NO SPEAKER WIRES ARE TOUCHIN THE OTHER, IF DONT WORK.. YOU WILL NEED TO TOUCH TWO WIRE AT A TIME, DID YOU HEAR SOUND BE4 INSTALLING
Mar 25, 2008 | Car Audio & Video
Lanzar OPTI1222D Car Subwoofer Logo
57 people viewed this question
Top Lanzar Car Audio & Video Experts
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
