Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
How do i reboot my 4gb cruzer flashdrive? - SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
  • ynotphone
    ynotphone May 11, 2010
    Sorry what????
    How do you reboot a jump drive?
    What are you trying to accomplish?
  • 3,153 Answers
San-disk has quite a bad reputation as far as quality goes especially with the cruzer drives. I have a pile of dead ones here in the shop.
But first check below and lets see if it is something more simple.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Posted on Sep 05, 2009
Write protection of flashdrive
Try this link
http://www.tomshardware.com/forum/284827-45-remove-write-protection-flash-drive
Mar 26, 2013 | SanDisk Cruzer Edge 4GB USB flash drive -...
How do you put music on a sandisk cruzer usb flashdrive
music download software
http://100-downloads.com/download.php?p=682 spotify Instant and legal access to over 10 million music tracks
http://www.artistdirect.com/music
http://mobile.afreecodec.com/free-songs-download-87079.html
once the music starts to download a browse option will open where you will need to select if you want to run or safe
you should always keep your antivirus up to date when using any file sharing programs on the internet
hope this helps
Jul 25, 2012 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My sandisk cruzer 4 GB pendrive ws working fine but now whenever i try to format\copy\cut it shows location 0 with used space 0 free space 0 what should i do
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Jul 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to rcover from my sandisk back to my library
1. Does the flash drive LED light up when you plug it into various computers? ( not just your own fortesting purposes).
2. Does it pop up in windows explorer at all? ( Should be labeled as Removable Disk by default)
Your flashdrive may have essentially died. Test this flashdrive on multiple computers to determine whether its your computer or the flash drive. If you are trying to recover information try out the app Recuva which can be found on google search. Your information may have been corrupted.
May 05, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk U3 Cruzer Micro 4Gb Cant Format
With your computer on and the SD Flashdrive fitted correct side UP in the USB port, go to 'My Computer' on the desktop and select the flash drive. The computer will ask you what function you want to perform on the drive and you must select 'format.' You did not say what kind of operating system you are using or I could give you more information. Let me know what happens,
Sciencewoman
Apr 01, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I want to download ms office 2007 in my usb how will i do that
Are you downloading the file or wanting to copy it from your computer to your flashdrive. If you are downloading it, you simply click on "save to" and click on the letter of you flashdrive. If you are copying from your computer, you just highlight the ms office folder and click "send to" and flash drive letter.
Jul 17, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Heating up, light not coming on
cruzer micro 4GB, loaded with data. works perfectly in all systems except my xp. Problem didn't originate until after ghosting system to correct different problem. Now, error message states flashdrive not recognized. must then get behind pc, and gently work with it until i can hear the shift in the duo core processors and the orange light on the flashdrive comes on. Please help.
Mar 10, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk cruzer micro flashdrive - not working on vista
you'll need to go to the sandisk site, and get a vista driver set..
Mar 11, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
USB Flashdrive shows full
Format your USB flasdrive..
Go to My Computer
Right click on removable disk and click the format..
Nov 19, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
181 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
