Question about Rain Bird Hardware & Accessories
I recently left town for 4 days and did not set tne timer for my rainbird system. When I returned and turned the dial, the sprinklers did not come on. The timer came on and the approriate minutes are working, but no sprinklers are coming on???
  • 582 Answers
CHECK THE VOLTAGE COMMING FROM THE TIMER TO THE VALVE WHEN THE TIMER IS IN THE ON POSSISTION IF NO VOLTAGE THE TIMER OR IF IT IS LOW VOLTAGE THE TRANSFORMER IS BAD. IF YOU HAVE POWER FROM THE TIMER THE COIL ON THE WATER VALVE HAS GONE BAD
Posted on Sep 05, 2009
Rainbird esp modular controller will not operate system -
Make sure that the transformer is supplying the 26 volts ac required by the pump relay and zone solenoids. If the voltage is there and unit still will not operate then the electronics are to blame.
Jul 22, 2016 | Rainbird Rain Bird Esp-4mi Esp Modular...
I need an operating manual for a 12 station Rain Bird computerised Irrigation system please. The person that installed it left without doing the demonstration and is now not contactable...
Check iside cover for rainbird 1-800 number and call them. Make sure you have the model number. They maybe able to email the directions or send you the manual. Additionally check youtube sometimes the go step by step on your model.
Mar 02, 2015 | Rainbird Rain Bird SST1200S Sprinkler...
Rainbird sprinkler manuals
Normally, when there is a battery for an item that has a cord that plugs into power, it is to keep "Memory" of anything programmed, in case power goes out.
Jun 01, 2014 | Rainbird Rain Bird Simple Set 6-station...
Rainbird RC-Bi timer issue
Copy following link to identify sprinkler & irrigation timers on market, and buy another one.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Install heavy-duty mechanical timer.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Replace sprinkler head
Check that voltage is at least 80% amount that shows on rating plate of timer. ie: 80% x 125V = 100Volts
Jun 29, 2013 | Rain Bird Hardware & Accessories
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Jul 27, 2011 | Intermatic R8806P101C -...
Have a intermatic sprinkler timer that is has been reconnected to the pump. it works in the manual mode but the timer does not work looking for help on the wiring (video for dummies preferred)
No video.
If manual override works, look to see if dial rotates on time for full 24 hours. If dial keeps good time, then timer clock motor is wired correctly. If dial stops rotating after tripper passes, then wiring is wrong. If trippers are absent or worn down then timer will not turn Load on-and-off.
How to set timer, and troubleshoot timer:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
How to wire timer:
You posted under R8806P101C 240Volt timer without rain sensor connections.
http://waterheatertimer.org/pdf/Intermatic-r8806p101c-manual.pdf
If this is not your timer, then add a comment with model number that appears on door panel.
The wiring block has 4 screw terminals. From left to right: 1 2 3 4
240Volts cable has two hot leads from breaker box. Hot leads from breaker box connect to screw terminals 1 and 3.
Timer operates 240Volt pump load. Cable to pump load has 2 wires. Connect Load wires to terminals 2 and 4.
Open following link for resources:
Jun 28, 2011 | Intermatic R8806P101C -...
How do you set the days that you want the system to operate ?
R88 series timers at Intermatic.
Click on model number to see manual:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Add a comment if you have different timer
At fixya, we're not supposed to copy-paste from manual, but manual says information clearly.
If timer has the day-skipper wheel located lower left of large yellow dial:
Not every timer has day-skipper wheel, in which case timer works same for each day.
TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
until today's day is in front of "14" arrow. Press pins DOWN on days
of NO watering. The skipper wheel must have all pins UP for daily
watering.
Additional instructions:
1. TO SET FIRST ZONE: For watering, push gold pin into slot on yellow
dial at desired ON time. For each 12 minutes of additional watering
add one pin WITHOUT skipping a slot.
2. TO CHANGE ZONES: Leave one blank slot on yellow dial after ON
line (gold pin), and valve will automatically advance to next zone.
3. TO SET ADDITIONAL ZONES: Repeat steps 1 and 2. REMEMBER
to leave blank space between zones
4. TO SET TIME OF DAY: Turn yellow dial CLOCKWISE, until correct
line is at end of silver time pointer. Do NOT turn silver pointer.
5. TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
watering.
6. PUT SELECTOR SWITCH IN AUTO: This switch can be used to turn
the system ON or OFF for manual operation without affecting the set
program.
Nov 24, 2010 | Intermatic R8816P101C -...
Hardware & Accessories Logo
291 people viewed this question
Top Rain Bird Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Rain Bird Hardware and Accessory Expert? Answer questions, earn points and help others
