My problem is I cannot access my router to enter my dvr information to view my cameras on line
I think your ip address is a dynamic IP. Therefore the address is changing. On your ip cctv camera, it is better you switch to Static IP so that it does not get changed...
For doing that you need to contact yopur internet provider to configure your IP camera IP address to Static IP...
Thank You
Posted on Oct 08, 2012
  • 335 Answers
Get to a command prompt and type 'ipconfig' - no quotes.
You will see some ip addresses listed. The gateway ip address is the ip address of your router. Put that ip address into the address bar of your web browser and it will take you to the router config page. This is where you can do port forwarding if you want to be able to view the cameras from outside your network. Post a comment if you need any more help.
Or did you just forget your router password........or is the router not responding......let me know :)
Posted on Sep 05, 2009
It tells me I cannot access the dvr at the shop to get live view. How do I fix this problem?
Check the connection from the DVR to the router. You may need to reset the router.
Oct 14, 2014 | Home Security
Connecting wireless cam with different ip address
An IP camera is a video camera that can be viewed over a Local Area Network or the Internet. The camera typically is monitored locally from a computer via the network to which the camera is attached. With just a few additional configurations of your network, you can access the IP Network Camera so that it can be monitored remotely using the Internet. This is the benefit of a network camera, as it can reside on an IP network and the video stream can be accessed or saved remotely.
Get the Default Gateway of your IP. Do this by entering "ipconfig/all" in your Command Prompt and hitting "Enter" on your keyboard. Your IP information will be brought up, and number you are looking for is the Default Gateway. This is underneath the IP address. Identify this number by its number pattern, which will look like the following: 111.222.3.4. Access your router. This is done by simply typing the default gateway from Step 1 above into the address bar of your Internet browser, and pressing "Enter." Forward your port by configuring your camera. Open the configuration section on the router web page where port forwarding is located by clicking on the "Applications & Gaming" link along the top of the page. In this menu, click on "Port Range Forwarding." Configuration sections can be located differently with each kind of router. Find this information by referring to the documentation that came with your router when you purchased it. Access your camera over the Internet. To do this, type your public IP address into the address bar of the web browser and press "Enter" in the same way as described in Step 2 when entering your default gateway. Note: The public IP address is different from your regular IP address. The regular IP address identifies computers and other devices on your network, whereas your public IP address is what is used to make yourself known to others on the Internet. Your Internet service provider can supply you with your public IP address if you call them and ask for it.
Viewing an IP Network Camera over the Internet http://www.networkcamerareviews.com/articles/portforwarding.html
Apr 18, 2013 | ASI Trendnet Wireless Tew-639Gr 300Mbps...
I cannot access my internet viewer
More details are required.
The Samsung 'SmartViewer' program starts up on a computer. You can access it whether you have a recorder or not.
The Samsung 4 channel DVR has a menu to set IP address & ports to use and a netjack to connect to internet. You can access the DVR from any computer connected to the same router as the DVR by inserting the same correct info into 'SmartViewer' as in the the DVR.
Once you open the required ports in your router, port forward the router to the DVR, any incoming requests from the internet to view should connect and with the correct password you can view your security cams.
With minor adjustments..that's it.
What didn't you do?
Dec 25, 2012 | Samsung 4 Channel Dvr
Can't view my cameras
The DVR will be programmed with an IP Address via the DVR main menu function (network settings) and a valid password. The network viewing software (web viewer) you will need to ensure that the IP address is entered correctly for your DVR along with your valid user password.
Trust the above info is of assistance if you require a manual in order to check your settings try this link http://tv.manualsonline.com/manuals/mfg/samsung/samsung_dvr_product_list.html
May 23, 2010 | Samsung 4 Channel Dvr
To veiw on the web I have to be home how can I make it operate from whereever I am even out of state?? Thank you Dan Richardson
Setting up DVR to be used from remote location:
  1. Connect your DVR to your router
  2. Use menu on DVR to assign internal IP and gateway and port number.
    This Local IP must be in the same Gateway range as the Router. If you are unsure check the Router and locate the Status section, or goto the command prompt of your windows operating system and type in ipconfig.
    Look for Gateway. If the Gateway is 192.168.1.1, then you can make the DVR's IP anything from 192.168.1.2 - 192.168.1.255.
    Also you will need to use the same SubNet Mask, which is typically 255.255.255.0, and also use the same gateway.
  3. Next find out what port your DVR uses. The easiest way to it is by reading the manual of your DVR. Look for the network section of it.
    Also if it comes with network software, check out if in the connection area the software shows the port number.
    Also check the Server software/Programming (Network section of it) to see if the port is listed.
    In many cases it will be as simple as just Port 80, which is an HTTP port.
  4. Set your router to forward chosen port to internal IP address of DVR.
    To access the Router itself, use the Gateway you just located. If the gateway is 192.168.1.1, then enter that into the location edit box of your browser and then click the Enter button. A username and a password are typically required, but it depends on a router. For Linksys use "admin", "admin". By default DLink doesn't require any username or password (It is highly recommended to change the default password).
    Once you're logged into the Router, in the Applications & Gaming Section / Servers of the Router, you need to add a Server/Application. Enter the port number and select TCP only. Where it says Port 0 to 0 enter the same port number twice. Or if your DVR uses for example, ports 3550, 4550, 5550, 6550, and there is nothing else utilizing these ports in between, then you can actually just enter one line, 3550 - 6550.
    Enter the DVR/Cameras internal IP.
    Enable it.
    Quote: Originally Posted by Example If the port was 1024, and the Local IP is 192.168.1.200, then it would be:
    NAME = Anything you want
    Port = 1024 TO 1024
    TCP/UDP = TCP
    LOCAL IP = 192.168.1.200
    ENABLED = CHECKED
    OR
    Port = 3550 TO 6550
    TCP/UDP = TCP
    ENABLED = CHECKED
  5. Set up additional entries for as many ports the DVR uses, to the same local IP. Check your DVR manual and it's networking section for all additional ports required. Also check the DVR software itself.
    If your router has enough free entries, you can seperate them. Use it like DVR_HTTP for the browser port, DVR_AUDIO for the audio port, etc.
    If you are going to use VNC to a PC DVR, then you would need to set up port 5900, and perhaps call it VNC_DVR, for example.
  6. You have a static IP so you don't need to use sevices like www.dyndns.org . You just enter your static IP and your router forwards packets to your DVR.
This info is from Stream recording found on http://stream-recorder.com/forum/connect-dvr-via-internet-watch-cctv-cameras-t1996.html?s=16e8433689f2d55effb40b16d5588895&
Nov 29, 2009 | Samsung 4 Channel Dvr
Not able to use remote viewing via no-ip
I had the same exact issue. I was using dyndns to connect, but i found out that when you login in the host, dont put your local ip address of the dvr, but instead put the internet ip address of your network. so instead of 192.168.0.5 for your local put the 89.137.24.124 for the internet address. That fixed my issue. Hope that works for you. Just make sure your username and password is right and the port is set up correct in your router to forward to the local ip of the dvr.
Mar 06, 2009 | GE Security Bc 1500 2.5 Ball Camera, High...
Can't access my DVR remotely via Video Server E
why i cant remote access my dvr in WAn but LAN is working fine?
Jan 03, 2009 | 2wire 2700HG-B Router (2700HGB)
Off site access to view security camara dvr
access the router look for portforwarding and enable port forwarding assign a name to your camera
type in the port your camera use. ex 593
then type the assign IP for your camera ex 192.168.1.6
to access it type in your browser the your public IP ex. 209.45.0.0:593
read your ip cam manual for accesing it.
Nov 12, 2008 | Computers & Internet
DVR camera system help
First, check what ports the DVR system uses, in GeoVision for example is:
80, 3550, 4550, 5550, 6550
So...
You DVR must be with Manual IP
And then, open the router management page and configure NAT settings, so that when someone in the outside network "calls" you ip+port, the router knows to which machine the "call" is...
Also... use some kind of dynamic dns service like DynDns or NO-IP so that people use an regular URL and not a IP address.
Aug 16, 2008 | Computers & Internet
CCTV-DVR
Have you given this computer Permission for you to remote connect, let me know?
Aloha
Bob
Jan 13, 2008 | Computers & Internet
Computers & Internet Logo
311 people viewed this question
David Payne
David Payne
