The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network. I hope this helps.
Please visit the Lexmark website to download and install the Lexmark X4650 printer driver on your computer. Select your operating system > download > execute the file. Just follow the instructions on your computer screen.
I`ll guess You`ll have to connect your PC to the printer with the use of a usb cable. Then run the Lexmark software (Lexmark printer home) or similar (don`t know what you are using?)... Go to "settings"; and choose wireless setup utility. You`ll have to manually set the SSID (the wanted wireless network) and the WIFI password for this network. Hope this will help.
If you have lost the disk you can download it from Lexmark website.
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_X4650&segment=SUPPORT&userlocale=EN_UK&frompage=null#1
How is your printer connected to your computer, wireless or hardwired with a USB cable? If wireless, check the status of the WiFi light on the printer (green = connected to a network, orange = not connected to a network). Try to turn off/on your printer. Doing this usually fixes minor communication issues. This article in the Lexmark website might also help resolve your scan problem: No Communications Error When Trying to Print or Scan.
Your firewall for the wireless is blocking the port. Go into your firewall settings and add the port from the printer to bypass the router. What operating system do you have? It should be in Control Panel under Security Center.
Let me know.
Ray
Yes the solution was very helpful. Thank you VERY much!
