Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
I vacuumed the condenser but the light stays on
And the freezer won't stay below 22.
  • 135 Answers
If the evaporator is frozen and has frost on it, then you have a defrost problem.
Posted on Sep 05, 2009
Freezer dropped to -12 won't stay at -1
freezer light does't work, I put in new bulbs and it doesn't stay cold.
Dec 06, 2011 | Sub-Zero 632 / S
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
The ice cube indicator is blinking
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Ice melts in the bucket on and off...
1check for frost 2 check light stay on 3 condenser fan 3 check door stay open
Mar 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Zanussi ZX 57/3 fridge and freezer not working
Hi . Most freezers with the condenser coils at the back do not work when the temperature where it is placed gets below (( 5 degree c ))?? IE in a garage if it is freezing weather outside. One solution is somehow to keep the condenser compartment warm. Check the makers website. for what they say about it
Jan 10, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero constant running, vacuum condenser
probably a  thermistor. common part to go bad in these units
Feb 05, 2008 | Sub-Zero 632 / S
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Jan 29, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
195 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
