Question about Swan Kitchen Appliances - Others
How do I clean the heating elements in my swan tea kettle. it looks like a mineral build up on the elements that comes off when the element is hot and the minerals fall into my tea water
Been using this fix for many years:
Get a large jug of the cheapest white vinegar you can find, fill your teapot with it (make sure the pot is cool and do not turn it on!!) and let it just sit overnight. You will notice that the inside of your teapot will be sparkling clean. Vinegar is about 4% acidic and it is the acid that dissolves the scale. After you are done, save the vinegar for use with other items aroung the home like shower heads, just remember that it takes a lot of time in contact with the solution for this to work.
The mineral buildup is Calcium Carbonate, which is just simple water hardness. Unfortunately as water gets hotter, this chemical has more of a tendency to scale up. Just the reverse of what you would think. So keep the tea or coffee pot cool during the soak.
Posted on Sep 10, 2009
  • 582 Answers
IF THE BUILD UP OF SCALE IS BAD YOU MAY HAVE TO TREAT SEVERAL TIMES TO CLEAN. VINIGER IS A GOOD CHOICE, JUST FILL ABOVE THE COILS AND LET SIT AND DO THIS AS MANY TIMES AS IT TAKES TO CLEAN THE COILS. ANOTHER GOOD PRODUCT IS CALLED- CLR MOST HOME DEPOTS HANDLE THIS PRODUCT IT STANDS FOR C-CALSIUM / L- LIME / R- RUST
THIS IS A LITTLE STRONGER THEN VINIGER BUT DOES THE SAME THING. BOTH WILL TAKE SEVERAL CLEANINGS
Posted on Sep 05, 2009
Cordless electrica tea Kettle---cord on heating element gets hot when in use.
  • Be careful, the type of wire in use may melt the insulation and cause a short/shock.
Jul 24, 2015 | Cuisinart Kitchen Appliances - Others
Red light's on... but no hot water!
HI,
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Goodluck,
Please don't forget to rate the solution
Apr 05, 2008 | Braun WK600 Cordless Electric Kettle
My Breville water kettle stopped heating water. This is my second teakettle to do this. We have had this second kettle for about 2 years. We always were careful to make sure the kettle is off before
Unless you can take it apart and repair it yourself, it probably isn't worth the cost to have it repaired. There are several websites that sell parts, but you really have to be familiar with electrical circuits to diagnose it. Possibilities are:
1. It could be the thermostatic switch that turns it off as it reaches temperature. These are little devices with two wires connected and are in the base of the unit. these normally reset themselves but can stop working, especially if they have gotten wet.
2. It could be the cord to the unit with a wire broken at the base or the plug end.
3. It could be a thermal fuse; these are about 1/4 inch in diameter and may be hidden in an insulating sleeve near the element; they are sensitive to both heat and current.
3. It could be the element is burned out.
Link to a parts supplier is enclosed
Breville Kettle Parts
Feb 04, 2015 | Breville Kitchen Appliances - Others
THE element does not get hot
Sounds like your tea kettle may have exceeded it's useful life. Don't know about Cuisinart, but generally these kinds of parts are not replaceable. I am afraid you may be looking at a new appliance. Sorry.
Apr 14, 2014 | Cuisinart Cordless Automatic Tea Kettle
Rinnai r94ls
This is a clear indication of what is called: "Hard Water"-- meaning that you have too many minerals in your drinking water!-- This problem is aggravated when you heat the water (as in your Hot Water Heate3r!)-- Heating causes the mineral (normally dissolved in the cold water)- to precipitate OUT when heated-- and thus they end up setting in your piping AFTER the heater.
Solution: YOu may have to install a water softener, to reduce the 'hardness' of your water.
Another aid, is lowering the water temperature of the hot water heater-- Can you do that, and still enjoy the bathing or showering with that water temperature? The lower the water temperature it is heated to, the fewer minerals will settle out in the piping after the heater. You must notice this problem in your Tea Kettles-- and your Coffee Maker?- Tell us more-- and we'll help you further.
Nov 02, 2013 | Heating & Cooling
Hot tub won't get hot enough
Low Heat -
This problem is not usually associated with the heater element but more often a result of water flow issues. Specifically blockages such as dirty filters, partially closed valves etc... But... excessive scale/mineral build up on the element is on uncommon and can result in reduced heating. The fix is easy, use chemical treatments to reduce scale build up.
No Heat
No heat or water is only heating to 60F- 80F? If you are getting a low reading this is because the water is only being heated by the friction caused by running through the plumbing system and pump. Assuming there has not been a dry fire (visual signs of burn/overheat marks/ damage to the heater tube) and your temperature sensor and hi limit are in working order.
A bad element. Like a light bulb, spa heater elements will burn out over time & there are many factors which affect their longevity.
Nov 25, 2012 | Home
Krups Tea Kettle isn't working. I believe the problem is in the handle. It doesn't heat the water.
hello,
the handle has noting to do with the heater what you need to check on is the connection from the power supply if the connection is alright then you will have consider the element it is the heat provider connected to the wire it means that it is weak it need to be replace with a better one the element is in silver colour you can get it in any technical store/shop around you.
thank you
Jun 10, 2010 | Krups Stainless Steel Electric Kettle...
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Nov 06, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
237 people viewed this question
Top Swan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Swan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
