Question about Sony VAIO VGN-FS640W Notebook
Remove keyboard data cable
How do you remove the data cable from inside the computer. There is a plasctic that seems to be holding it in place and I can't tell from looking at it how to replace it. Any help would be appreciated. It is a VGN-FS640 sony vaio.
Thanks.
  • 21 Answers
That plastic piece is a retainer,gently pull up on both sides and you should get your ribbon cable out. pay close attention on how it came out.
Posted on Dec 08, 2007
How do i open dv7-1451nr?
Instructions
Shut the Pavilion dv7 down and close the screen. After unplugging all cables from the computer, turn it over and remove the battery.
Unscrew the six Phillips-head screws holding the large T-shaped panel to the bottom of the Pavilion dv7. Remove the panel and set it aside.
Remove the keyboard locking screw--marked by a keyboard-shaped icon--from the top part of the compartment exposed when you removed the T-shaped panel. Reserve the screw.
Remove the black Phillips-head screw from next to the wireless adapter inside the T-shaped compartment. This screw holds the Pavilion dv7 optical drive in place.
5
Pull the Pavilion dv7 optical drive gently out of its bay, and then remove the two Phillips-head screws from inside the empty drive bay. Reserve the screws.
6
Remove the Phillips-head screw next to the circular intake fan vent in the corner of the Pavilion dv7.
7
Remove the five Phillips-head screws from inside the empty battery compartment. You should now have removed 16 screws in all. Turn the Pavilion dv7 over and open the screen.
8
Insert a spudger or other flat plastic tool into the seam between the speaker grille and computer casing on the right side of the Pavilion dv7. Gently pry up to begin removing the speaker grille from the computer. As you do this, move the spudger to a new location to pry different areas until the grille is completely disconnected. Mind the ribbon cable connecting the center of the speaker grille to the logic board, and do not lift the grille any higher from the computer than the cable allows.
9
Push both sides of the speaker grille cable lock forward until the cable slides easily out of the logic board connector. Set the speaker grille aside.
10
Remove the four Phillips-head retaining screws above the top row of the Pavilion dv7 keyboard. Lift the keyboard up and forward, and place it face-down on the palm rest.
11
Unlock the Pavilion dv7 keyboard cable connector using the same method as for the speaker grille connector. Slide the cable out of the connector, remove the keyboard and set it aside.
12
Place the new Pavilion dv7 keyboard upside-down on the palm rest. Slide the keyboard into the connector, close the lock and rotate the keyboard down into the computer. Replace the four Phillips-head screws.
13
Slide the speaker grille cable into the connector and close the cable lock. Push the speaker grille into its original position above the Pavilion dv7 keyboard. Press gently on all parts of the speaker grille until it is flush with the computer casing.
14
Close the screen and turn the computer over. Replace the five screws inside the battery compartment, the screw next to the intake fan vent, the two screws inside the empty optical drive bay and the screw inside the T-shaped compartment.
15
Replace the t-shaped panel on the bottom of the Pavilion dv7 and its six screws.
16
Slide the optical drive back into its bay and replace the securing screw.
Jan 10, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Tip
How do replace keyboard on a dell 15 ?
It’s easy to break the flimsy keys on most laptops. Sometimes it’s cheaper to find a laptop keyboardfor your model laptop elsewhere than going through the manufacture. Ifyou find yourself in this situation, you can use these steps to replacethe keyboard. take “Dell Inspiron E1505 Keyboard” for example:
Dell Inspiron E1505 Keyboard US
Removing the Damaged Keyboard…
Enusre the laptop is fully powered off, unplugged from the wall, and the laptop battery taken out.
Turn the laptop over. On some models icons indicating which screwsare attached to the keyboard are displayed. If not, you may have to“eyeball” it if you can’t find a breakdown for your model (such as dell pa 12 or pa 10)online.
Remove those screws with a T-8 or Phillips screwdriver.
Turn the laptop back over and open it up. Check and see if thekeyboard is tucked under any plastic pieces. If so, find if thoseplastic pieces are screwed into anything, and unfasten them as well. Ifnot, it probably uses clamps that can easily be removed.
Remove the plastic pieces carefully with a toothpick or plastic pick if there is any in the way.
Unscrew any screws at the top (if necessary) and remove the keyboarditself from top to bottom. You’ll notice that the keyboard is connectedwith a thin, but wide, data cable to the system board at the bottom.
Take that same pick and lift the plastic connectors that hold in this data cable in place.
carefully remove the data cable. Now the whole keyboard should be free.
Replacing the keyboard.
Take the new laptop replacement keyboardout of the plastic, and slip the data cable back in between the plasticconnectors on the system board. Make sure it’s all the way in.
Use the pick to push the plastic connectors back into place, and make sure it’s holding the data cable in.
Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
Refasten the keyboard in place at the top.
If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
Turn the laptop over and replace all of the keyboard screws.
Finally, put the battery back in and power on the laptop. If all hasgone well, the keyboard should be functioning like brand new.
on Jan 19, 2010 | Computers & Internet
Remove the cover on an emachine e525
Umm, well there are things like the motherboard and plamrest that have screws in them that might be holding it. You just can't remove the bottom cover, You have to start by Removing the bottom screws like you did, but then you have to remove other things before you can get the bottom case off. Also the VGA Port might have screws on both sides of it that keeps the bottom case from coming off.
Below are some steps to follow.
Look inside the battery case, hard drive case, memory case and dvd drive slot for screw. Some screws on the bottom case in inside of some of the device cases might have the icon of a keyboard next to it. Those screws hold the keyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but be careful because a cable might be attached to it. Then remove the screws that hold the keyboard in place that are under where the strip was and gently lift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift the lcd screen off, also note that you will have to pull the antennas cable and the lcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note of any cables that are attached to the palmrest and remove them then lift the palmrest off.
Next start removing any screws you see that hold the motherboard to the bottom case, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory of where things were.
May 31, 2012 | Computers & Internet
Disassmbly guide
Look inside the battery case, hard drive case, memory caseand dvd drive slot for screw. Some screws on the bottom case in inside ofsome of the device cases might have the icon of a keyboard next to it. Those screws hold the keyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but becareful because a cable might be attached to it. Then remove the screwsthat hold the keyboard in place that are under where the strip was and gentlylift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift thelcd screen off, also note that you will have to pull the antennas cable and thelcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note ofany cables that are attached to the palmrest and remove them then lift thepalmrest off.
Next start removing any screws you see that hold the motherboard to the bottomcase, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory ofwhere things were.
May 26, 2012 | Computers & Internet
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
Steps to replace keyboard
  • Hi there here's the steps on how to replace a laptop keyboard :)
    Take the new keyboard out of the plastic, and slip the data cable back in between the plastic connectors on the system board. Make sure it's all the way in.
    2.Use the pick to push the plastic connectors back into place, and make sure it's holding the data cable in.
    3.Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
    4.Refasten the keyboard in place at the top.
    5.If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
    6.Turn the laptop over and replace all of the keyboard screws.
    7.Finally, put the battery back in and power on the laptop. If all has gone well, the keyboard should be functioning like brand new.
  • Sep 29, 2011 | Computers & Internet
    How to remove the keyboard of a HP Mini 110 3130sv
    1. Enusre the laptop is fully powered off, unplugged laptop ac adapter from the wall, and the battery taken out.
    2. Turn the laptop over. On some models icons indicating which screws are attached to the keyboard for HP Mini 110-3130sv displayed. If not, you may have to "eyeball" it if you can't find a breakdown for your model online.
    3. Remove those screws with a T-8 or Phillips screwdriver.
    4. Turn the laptop back over and open it up. Check and see if the HP laptop keyboard is tucked under any plastic pieces. If so, find if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
    5. Remove the plastic pieces carefully with a toothpick or plastic pick if there is any in the way.
    6. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, ribbon cable to the system board at the bottom.
    7. Take that same pick and lift the plastic connectors that hold in this data cable in place.
    8. Carefully remove the data cable. Now the whole HP Mini 110-3130sv replacement keyboard should be free.
    1. Take the new keyboard out of the plastic, and slip the data cable back in between the plastic connectors on the system board. Make sure it's all the way in.
    2. Use the pick to push the plastic connectors back into place, and make sure it's holding the data cable in.
    3. Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
    4. Refasten the keyboard in place at the top.
    5. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
    6. Turn the laptop over and replace all of the keyboard screws.
    7. Finally, put the battery back in and power on the laptop. If all has gone well, the HP Mini 110-3130sv Keyboard should be functioning like brand new.
    Sep 01, 2011 | HEWLETT-PACKARD Mini 110-1031NR Netbook
    Evon610c keyboard keys broken how to replace the keyboard ? how to open the case with out damage internal parts ??
    Hi
    this may help you i found it somewhere online
    How to Replace the hp compaq evo n610c laptop keyboard Removing the Damaged Keyboard
    Enusre the laptop is fully powered off, unplugged from the wall, and the battery taken out.
    Turn the laptop over. On some models icons indicating which screws are attached to the keyboard are displayed. If not, you may have to eyeball it if you can't find a breakdown for your model online.
    Remove those screws with a Phillips screwdriver.
    Turn the laptop back over and open it up. Check and see if the keyboard is tucked under any plastic pieces. If so, find if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
    Carefully remove the data cable. Now the whole keyboard should be free.
    hope this was helpful
    Jun 21, 2011 | Compaq Evo N610C Notebook
    How do I replace keyboard on a asus 1000HD
    HI
    It’s easy to break the flimsy keys on most laptops. Sometimes it’s cheaper to find a keyboard for your model laptop elsewhere than going through the manufacture. If you find yourself in this situation, you can use these steps to replace the keyboard.
    Removing the Damaged Keyboard...
    Turn the laptop over. On some models icons indicating which screws are attached to the keyboard are displayed. If not, you may have to “eyeball” it if you can’t find a breakdown for your model online.
    Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You’ll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
    Take the new keyboard out of the plastic, and slip the data cable back in between the plastic connectors on the system board. Make sure it’s all the way in.
    Thanks for contacting fixya.com
    Dec 03, 2009 | ASUS Eee PC 1000H Laptop
    I need to install a keyboard for a Dell Inspiron 1525. I need step by step directions
    Before you begin, Follow these steps carefully;
    1. Shut Down to turn off your computer. Ensure that the computer is off and not in a power management mode. If you cannot shut down the computer using the operating system, press and hold the power button for 4 seconds.
    2. Disconnect your computer and all attached devices from their electrical outlets. Disconnect any telephone or network cables from the computer
    3. Remove any installed cards from the ExpressCard slot.
    4. To help prevent damage to the system board, you must remove the battery from the battery bay before you service the computer. to do this, Turn the computer over, Slide the battery release latch until they click into place. Slide the battery out of the battery bay.
    5. Turn the computer top-side up, open the display, and press the power button to ground the system board. Now you are ready to remove your Keyboard;
    6. Removing the Center Control Cover, Remove the two screws securing the center control cover from the battery bay,
    7. Turn the computer top side up, and open the display as far as it will open.
    8. Insert a plastic scribe into the indent to lift the center control cover on the right side and ease the center control cover up.
    9. Disconnect the cable from the media control buttons connector located underneath the center control cover. NOTICE: To avoid damage to the data cable connected to the system board, ensure that you do not pull hard when you are raising the center control cover. NOTICE: To avoid damage to the center control cover, do not lift the cover on both sides simultaneously.
    10. Remove the center control cover.
    11. Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
    12. Lift the keyboard and hold it up and slightly forward to access to the media control buttons connector.
    13. Disconnect the media control buttons connector and remove the media control buttons cable.
    14. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
    15. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer.
    16. Slide the keyboard cable out of the keyboard connector.
    17. Replacing the Keyboard
      1. Slide the keyboard cable into the keyboard connector.
      2. Rotate the keyboard connector latch to secure the cable.
      3. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
      4. Press on the right edge near the top to snap the keyboard into place.
      5. Replace the two screws on the top of the keyboard.
    18. Replacing the Center Control Cover
      1. Reconnect the media control buttons cable to the connector below the keyboard.
      2. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
      3. Press on the right edge near the top to snap the keyboard into place.
      4. Replace the two screws on the top of the keyboard.
      5. Reconnect the media control buttons connector to the center control cover.
      6. Insert the left edge of the center control cover.
      7. Press from left to right until the cover snaps into place.
      8. In the battery bay, replace the two screws that secure the center control cover.
    Apr 17, 2009 | Dell Inspiron 1525 Laptop Jet Black
    Sony VAIO VGN-FS640W Notebook Logo
    122 people viewed this question
    Top Sony Computers & Internet Experts
    Alun Cox
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
