Question about Mitsubishi WS-55511 55" Rear Projection Television
Volume increases to 30 can't turn down
Now i can"t turn tv off with remote or off button on tv, have to disconnect. No response to remote control, I check batteries they are fine. I've reset the unit. No response.
I don't have a solution but if you take off the speaker grille on the front of the set and see two ribbonish cables, unplug the smaller one. The volume will not increase anymore but you cannot use the controls on the front of the tv and the power light will not show green anymore. You can however use the remote to do everything on the set that you would normally do. Hope this helps until I find a real solution.
Posted on Nov 02, 2009
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
I have a Sharp Aquos LC-46D43U TV and the audio control is continuously going down to zero although I use the remote to increase the volume. The TV is automatically decreasing the volume to 0. I hea
this is a problem I rectified yesterday.
the audio ic is overheating thats why the tv is fine when cold and
after a few hours the volume disappears.
I fitted a heatsink to the ic chip as the sharp one is very poor quality
Sep 19, 2014 | Televison & Video
Volume intermittently increases all the way to 100 and cannot be controlled by the remote
This happens with some models. You can open the TV from the back and disconnect the connector for the side control board. You will only have control via the remote but your volume issue should be resolved.
Apr 12, 2014 | Samsung Televison & Video
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Volume automatically goes to maximum on TCL TV
The volume (+) button on the TV is stuck or soiled if the volume automatically increases when the TV is turned on. To find out:
  1. Turn off the TV.
  2. Press and hold the volume (-) button on the TV then turn it on.
  3. If the volume doesn't automatically increase, you have a stuck button.
  4. If it does increase, you have a faulty key control board.
  5. In either case, you have to replace the key control board.
To find it out further:
Warning: Beware of electric shock.Please do not proceed if you do not have the skill to do the following.
  1. Unplug the TV.
  2. Let it stand for 15 minutes to allow voltages to drain completely to avoid the risk of electric shock.
  3. Remove the screws securing the TV's back cover and pull it off.
  4. Disconnect the cable that runs from the main board to the control key board.
  5. Turn the TV on using the remote.
  6. In this manner you can use the remote control to run the TV while waiting for the control key replacement board.
To do a hard reset of the TV, unplug it and let it sit for 2 hours or long enough to completely drain the internal voltages.
Nov 20, 2009 | Televison & Video
TV won't stop changing channels
Main board needs replaced !
Jul 03, 2009 | Televison & Video
Volume increases on its own intermittently
When the volume increased did the display show it doing so as if someone was turning the knob?  I mean did the volume go from like level 15 to 30 or did the unit's level stay constant while the audio volume increased?
Were you alone or sharing the room with a jokester who has a universal remote?
Does this problem occur when the batteries are removed from your remote?
Are you sure the 'volume up' button on the unit itself is disengaging properly after being pressed?
Dec 18, 2008 | RCA RT2760 System
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
