Question about Cell Phones
My phone is only powering partly then frrezing. I have no function. Change battery nothing. need to phone to work so I can access my contacts.
  • 2 more comments
  • franlara604 Sep 05, 2009
    sorry still upset, I was paying $2.00 a month for back up, however when i purchased the plan sales rep told me it was registered. However I was not. Bought a new phone. Old phone is a Samsung SGH a437. numbers stored on phone not sim card. i need to power up the samsung to extract numbers. DO not want a factory reset as this would delete numbers.
    the power cord does not work. But i think the hacker is on to something, The phone feels hot. I will try the tupper ware thing if it does not work I will holler back tomorrow. AT&T was absolutely no help nor samsung,
    Did the tupperware thing still did not work. The phone numbers are saved to my phone not my sim card. the phone is registered, the sales rep did not register the phone back up. I would like th ephone to power up long enogh to save phone numbers to sim card.
    not working yet
    President:
  • 2,600 Answers
You need to be more specific in the problem, I need to know what phone you have and what service or carrier you have. If you Verizon, they have a program called back-up assistant that will transfer your contacts over the airwaves to another phone you get. Your contacts are tied to your phone number so it may not be necessary to have your present phone powered up. Also depending on the phone you have and carrier, your contacts may be carried internally on a SIM card which is removable and can be transferred to another phone that uses SIM card technology so you won't lose any settings, music, pictures, contacts...etc. Good luck, ParrotHead PC Repair
Posted on Sep 05, 2009
  • Chip
    Chip Sep 05, 2009
    Been there...done that....I have Verizon so they keep numbers on their
    data base...I lose stuff too easy. OK, if you are getting it to power
    on somewhat, try to hook it up to the charger so it is not relying
    solely on a battery that may not be delivering enough volts even if it
    is saying it is full, you need to have a steady and reliable power
    supply. Once that is done, try putting in *228 and hit send...I need to see if this triggers a phone program update, if ir does listen to the prompts if any and hit (1), wait for it to program and then hang up. If it doesn't get to that point, you may have better luck explaining your position to them and maybe they can get the phone registered and powered up long enough to make a backup for you. I hacker told me that there may be an issue with these things overheating and causing the freezing and shutdown. He suggested wrapping the phone in multiple layers of papertowels and placing the phone in a tupperware bowl and pushing the lid on getting as much air out as you can and leaving it in there for an hour and trying to power it up after that to see how long it will stay powered up. Whatever the case, that number has to be registered with the service so they can tie the contacts to it. Do not just go by what one guy says...ask around in the service areas and I bet you get different opinions from whoever you ask. Some people are smarter and more street wise in these fixes. Good luck, ParrotHead PC Repair
Appoint function to knob
Access it through control panel then go to power options then click on choose what pressing power button does option then select nothing or shut down just a guess as you haven't put much detail's hope this helps Sean
Oct 25, 2014 | Computers & Internet
Phone frrezed
I would love to be able to help you fix your phone problem, but although you mention the make and model I don't know what you mean when you say "phone frrezed". Could you write back explaining what happened to it and if any of the functions are working? The more information you can tell me, the better I shall be able to help you. Thanks.
Aug 22, 2011 | Samsung E1080 Black OPTUS Cell Phone
Me screen will not function, it is visible on the phone, but is locked up and none of the touch features work. When I slide to unlock, nothing happens. I am receiving phone calls and texts but cannot...
Your phone is frozen, you need to hold the power and the home button together for at least 20 seconds. The phone it´s going to reset then it´s going to show the apple logo and then turn off. Then press the power button for 3 seconds and wait for the phone to restart.
Feb 19, 2011 | Apple iPhone Smartphone
Does not let me access the icons nor display them.
its due to 2 problems
1)you need to change the flex that connects the lcd with the main board
2) you need to get the software upgraded for ur phone
thanks .please vote for me if it works for you
Apr 24, 2010 | Samsung SGH-U600 Cellular Phone
When i put cherger its power up other wise nothing happend, pls help me
Hi!
Normally this would indicate a problem with the battery or faulty/loose connection with the elements that connect the battery to the rest of the phone.
When you plug the charger in, the phone will use that as it's source of power & bypass the battery to function. When it's turned on does the battery charging indicator light up at all?
Try a different battery (some mobile phone shops will have a few spare or at least one compatible to test it out). If that works, you know what your problem is. If that doesn't work, unfortunately it's probably something wrong with the phone's hardware. If it's under warranty, contact Samsung & they can do a repair.
Hope this helps :)
Nov 20, 2009 | Samsung SGH-G600 Cellular Phone
Power switch no longer works nothing works except
Please contact the below for service.
Online: customerservice@sharperimageonline.com
Phone: 1-877-714-7444 8:00 AM - 8:00 PM EST Monday - Friday
Oct 30, 2009 | Sharper Image Travel Soother 20 Clock...
All functions except picture taking work on camera
Problem with lens assembly. No user solution. Contact service.
Aug 17, 2009 | Sony Cameras
The bottom part of my touchscreen will not function... so I can't access ipod, safari, phone or email... the application buttons function, but not at the bottom once I open them.
2G or 3G ?
either of them you have to change the part to put it work again !
2G - You have to change the complete LCD with Touch . 3G - You can only change Touch !
need supplier ?
Let me know ;)
Jun 22, 2009 | Apple iPhone Smartphone
Lg chocolate 8500
unfortunately, this is the chocolate's white screen of death. there's really nothing you can do to fix it.
Jan 03, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Not working nokia 6060
my nokia 6060 power on but says contact service, how do i resolve?
Mar 08, 2008 | Nokia 6060 Cellular Phone
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
