Question about Canon imageRUNNER C3220 Color Copier
No Power The copier was on and I could not see it from my PC to print so I wiggled the network connector on the back of the machine and the machine shut done and will not power back on ... I tried pulling the plug and re connecting nothing seems to work ... YIKES have a print job to do this weekend ... Help ...
    Problem Solver:
  • 16 Answers
Ok, let me also help u. it seems that u have two problem at now, but after managing puting your copier on first of all make sure that the machine is in printer mode and not in copier or fax.
Posted on Sep 08, 2008
See mcb
Posted on Mar 21, 2008
    Problem Solver:
  • 18 Answers
I,ve seen this when a network board goes bad. even after replacing the board it was still dead. check tose by some freak chance a fuse on 1 of the boards is bad, (if there are any) make sure it s actually NOt just a bad connection. I know it may sound silly, but check the wall utlet. I had a guy blow a fuse ina nother part of a building, and knocked out my copier. I scratched my head for an hour. Also, be aware of those stupid shut-off switches located onthe back (such as kyocera) that get turn off by accident, That one stumped me for a couple days, not realizing some idiot pushed while cleaning behind the copier. By the way, i,m not an apprentice like it says.
Posted on Dec 08, 2007
How do I fix error cf 248 for my Kyocera 1128. I have tried several times shutting off. Taking out toner and checking paper jam
If its what I think it is, then the error occurs when your machine is receiving a corrupted print job. This is shown by the data light flashing for several minutes before showing the error.
If this is the case, then unplug the network cable from the machine, power the machine off & on & wait until it comes ready. If the machine comes ready then try a photocopy. If that works then it is a corrupt print job. Before plugging the network cable back in, check any PC's that print to the copier & check the print queues to see if any PC's are still spooling a print job. If so, delete the print job & re-connect the network cable & test the machine.
I have found most corrupt print jobs will be from the internet & will have "www......" listed as the print directory list.
Hope this helps.
Dave.
Feb 13, 2016 | Kyocera Office Equipment & Supplies
F9-88 code on arm317
F9-88 = Print PCB to Main MFP Board Comm Timeout
You can clear this by turning your copier off and then on. Try turning it back on with the network cable unplugged, run your machine, then plug the network cable back in. If the error code comes back, its: 1) bad network cable 2) ungrounded electrical plug for copier or router 3) noise on network line 4) copier needs firmware update 5) replace the print board
Apr 02, 2014 | Sharp AR-M317 Black and White Copier
Looses connection with network
Common for this printer. Instead of setting it up as a network printer, attach it locally to a machine and share it. It will be much more stable.
Aug 09, 2012 | Lexmark T620 Laser Printer
My HP Photosmart 2710 keeps shutting down, either when printing, scanning, or sometimes just on its own. I can only get it to restart by removing the power plug from the power supply and reinserting it
The most common reason for this is that the power input in the printer has a bad solder joint.
Wiggle the power connector at the back while the unit is powered up.
If it goes off, then that connector inside the printer just needs to be soldered back down.
The other possibility is that the power adapter itself is failing, which is really hard to test without another power adapter to test it with.
Mar 19, 2011 | HP Photosmart 2710 All-In-One InkJet...
HOW DO YOU NETWORK A canon imagerunner 1023
do You want to connect the machine on network or .... ?
First check if you on back side of copier have the network connector.
If yes, you need to connect the normal network cable if you have network switch or cross cable if you are connect directly on PC.
Then you must enter the IP adress in machine, under user mode (*) under system settings, under IP adress.Also enter subnet and gateway adress.
Free IP adress you can check on your pc under CMD and type ipconfig, to see your ip, subnet, and gateway.Then type : ping XXX.XXX.XXX.YYY The YYY marks number that you can change and must not be same as yours PC.After typing ping .......... and you have answer DATA LOST that means the ip is awailable and you can type it in copier.
Install drivers and select tcp/ip port.
If these isnt solution that you asked for, you can also contact me on emma.servis@gmail.com with more detailed description.
Hope that helps!
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
Copier
If it is flat out dead there is a simple fix.
Turn the machine off, and on the back of the machine disconnect the white connector with the 2 thumb screws. Then turn the machine back on with that plug disconnected. Let it come to ready, shut the machine back off, plug the connector back in, tighten the 2 thumb screws and power it back up and let the software re establish communication with the document feeder.
For some reason the machine will forget it has the document feeder.
There is also a version 3.2 firmware on Xerox.com that prevents those problems and also makes copy quality much better.
Jun 04, 2008 | Xerox CopyCentre C20 Black and White...
Printer not receiving jobs from computers in office..HELP!
what type of connector do you use? if its network printing then check ip address, cable, and the network card of the machine if it shows light, if its usb cable check the driver or cable.
note: make sure when you press the print buttom on the machine it doesnot show offline! if it shows offline you cannot print hit go or start to make it online.
if none of this work, reset the machine by hitting 1087 twice this will take you to maintenance mode then hit 906 then start, highlight the words that come on screen by your finger then hit start, the machine will ask you to put the main power on and off, do that and you will be fine.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Feb 15, 2008 | Kyocera Mita KM-2050 Printer
Canon imageRUNNER C3220 Color Copier Logo
54 people viewed this question
old marine
old marine
