Question about Amana 3.2 cu. ft. Top-Load Washer
Tub does not stop filling up and water is leaking onto the floor
    President:
  • 1,776 Answers
Check for a faulty water level switch. This is a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level it activates the switch to turn off the water. Look for any obstructions in or damage to the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check fo continuity. A lack of continuity indicates a faulty switch. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 05, 2009
Moffat washer
Your water level has a reset on the panel? You need to drain all the water out of the tub and turn the water level to the lowest setting. Now start the fill and watch the water come up. It may be that it needs to be looked at but it is just a hose on the side of the tub that fills and air pressure registers in the control panel that stops the water filling.
Jan 08, 2014 | Washing Machines
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
Float switch dripping water onto floor while dishwaser running
You will find that the flood switch will be operating due to the leak, it will most likely be from one of 2 places:
1. Around the door seal, Give it a clean and check for splits/damage, and make sure screws on door hinges are tight.
2. Check the rollers that screw onto the inside of the dishwasher cabinet, The screws on these can come loose and cause water to run down into the base, check they are tight.
Hopefully this helps.
Mar 04, 2012 | Dishwashers
I have a maytag neptune MAH5500BWW. Everytime the water company shuts off the water to repair a leak, the tub fills with water, sometimes overflows onto the floor. Works just fine when there is pressure...
This is symptomatic of a malfunctioning water control valve- depending on whether it is hot or cold water with which the tub fills.
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
Tub fills up with water 2-3 hours after washer cycle is finished. leaks all over floor
I replaced the water inlet valve to stop water filling tub when machine was off. was very dissatisifed with first solution you gave me, Just went out and got water water inlet valve and replaced it, before I got the second e-mail
Jan 08, 2010 | Tappan Dishwashers
My roper washing machine wont stop filling, water just keeps running until it runs over the top of tub and onto floor. I was just wondering if the switch controls the water level of is there something on...
If when you shut off or unplug the machine, the water stops response #1 is correct.
If shutting it off or unplgging it, doesn't work and you have to shut the water off at the shut off valves, the dual water valve is bad.
Nov 02, 2009 | Washing Machines
Washing Machine Emptying
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
May 27, 2009 | Washing Machines
GE top load washer leaks on floor
Check your hoses mostly the small hose going from the side of the tub to the water switch these come off a lot. you need to look and see if the seal is leaking from the center of the tub you do this by putting water in the tub and just looking around the bottom of the tub and transmission
Dec 29, 2007 | Washing Machines
Amana 3.2 cu. ft. Top-Load Washer Logo
67 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
