Question about Mitsubishi WS-55809 55" Rear Projection Television
Can not convergence
Will not convergece from menu
  • Anonymous Dec 09, 2007
    Ive tried the 4 hour unplug reset and it worked fine for approx 15 min.
    now i dont know which board is which.
  • script Sep 24, 2008
    My side to side convergence works, but the up and down doesn't. The colors are diverged going out from the center of the screen.
  • 934 Answers
Check for poor solder connections on both StK392-570 convergence Ics (Mitsubishi p/n # 267p150010) If there are none you may have to replace the amps - but that should restore normal convergence..
Bill
Posted on Dec 08, 2007
Sony model kp57ws510 rear projection. convergence problem. convergence button on front of tv does nothing
There are a set of convergece chips that need to be replaced. If they have been replaced and you still have the convergence problem you will need to change ceramic fuses in the power supply or on the board where the STK chips are located
Mar 04, 2010 | Televison & Video
How to do convergence adjustment on 46 inch sony
Use your flash foucus or goto your menu - and choose convergece. Some sets may not have this feature. You can also put the set if service mode and make adjustments but I would not reccomend that unless you know what you are doing. None of the above will work if your convergence chips have failed. If that is the case you can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 01, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Cant find auto convergence in menu
Thats a common problem that is usualy corrected by replaceing FL231, DL231 and CP230 you can get the parts with instructions on how to do the repair at the following link. Cost about 11.00 shipping is free. The parts are listed under the RCA parts category.
http://servicemanuals.vstore.ca/
May 29, 2009 | Televison & Video
Lost convergece and not on the tv menu
Simple problem to fix for a professional; pretty hard to do yourself. There are bad connections on the flyback transformer and a fuse is open. Where do you live; i'm due for a road trip.
May 12, 2009 | RCA R56WH76 Projection Television
How to find the convergece amps
On that chassis the only fuse affecting convergence is a 400ma pico fuse near the flyback transformer. If this fuse is open the signal board will never send the "ON" command to the convergence supply so the convergence will be dead.
If the pico isn't open then suspect the amps themselves or possibly an open resistor or two.
Bill
Dec 02, 2008 | RCA HD52W59 HDTV Projection Television
Big Screen problem
What did you put in. convergence amp or convergence power. this is a rca hd52w59? i always ask the question in customer menu under setup can you see the option of convergence. if not this is the fl231 fuse problem. consult the article fl231 under tips and tricks section of my profile. the curved picture is an indication complete loss of convergence power. there is a board that does provide convergece power. The convergence on this set is controled by three diffrent boards. power,amp and the small signal board. the small signal board is the most expensive and most complicated to replace ussally a tech has to replace that.
Nov 08, 2008 | RCA HD52W59 HDTV Projection Television
Dual pictures in diffeent colors
I dont recommended buy convergence board.... Time to fix it !!. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms. If you have questions? noetvs@embarqmail.com . Good Luck !!
Jul 20, 2008 | Philips 60PP9202 60" Rear Projection...
Rca rear projection hdtv lost color convergence
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
Toshiba tv model # tp55h60
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 04, 2008 | Toshiba TP55H60 55" Rear Projection...
HDTV convergence going bad
convergence is tricky.. there are three seprate boards that it is split with.. do you have NO convergece at all.. could be convergence power board...one color... convergence amplifer board.. it it could be the signal board.. there's even a chance it could be a descrete fuse... shoot me some more info..
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
