Question about Kirby G4 Bagged Upright Vacuum
Motor wont turn on.I checked the switch and I think it is working.motor turns on if a put direct power to it.`but it smokes at the brushes. can you help?
    Sergeant:
  • 332 Answers
This sounds like either the belt isn`t on right or the brush is not slotted in the vacuum right remove the plastic or metal cover from the bottom and check by inspecting the belts ability to easly turn the brush rod check with your hands DO NOT turn vacuum on while plate cover is off it could fly off and cause injury.
Posted on Sep 05, 2009
Agitator wont turn
It could be one or more of a few causes. Easiest to check is the belt and/or brush roll. There are two switches for the brush roll. Both must be working properly. One is by the main power switch and the other is in the motor compartment. If the problem still persists check the brush bar motor in the power nozzle assembly
Feb 23, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Compact electra C9 vacuum power head wont turn on
Have you checked the electricity is getting to the motor? You can replace the motor if necessary.
Jan 17, 2014 | Electrolux Epic 6500 Vacuum
Vacuume will not turn on. I checked for power in the switch and there was. What else should I check for?
SHORT carbon BRUSHES in the motor look on one of the two brushes the autostop protection protrudes at the front of the brush out. replace not direct the brushes , look for a healthy brass-colored wire of the stator field and armature if its dark beware of a short time of pleasure if the collectors are damaged if the engine has had its operating hours because of heating by fine dust cocked filters by time new brushes can have be shorted in a very short time again , and therfore is a brushes replace to expensive .
or a electric field contact a little change if its not a defect collector in the armature turn the motor a little on the top fan and switch the vaccuum on replace the motor if its run with bad noise replace the motor directly by a equivalent FIXAPART brand or any good equivalent , differs on the age of the whole vaccuum what the customer preferred.
Oct 16, 2010 | Fein 9-55-13 Turbo II Bagged Canister...
No power when turned on, I checked motor brushes and they are almost worn out, could this be the problem? and where do I find replacement brushes? I have checked on Dirtdevil's site but I don't see any...
Before that I wouild check the switch...the switches on those things go bad regularly...get a meter and check the power on either side of the main switch and I think your problem will be there...
heatman101
Apr 29, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Hello. I took the sole plate of to clean the brushes on my dyson dc14 however the brush part came out and i put it back in but since then whenever i switch it over to carpet setting it makes this really...
You really need to take the sole plate back off and make sure the belt is running exactly where it's supposed to go and not looped over a piece of plastic or anything. More important is that you make sure the ends of the brush are seated properly and the bearings the brush is mounted to are clean and rotate freely. Look at each component and make sure they are assembled perfectly. Make sure a plastic ring or piece that goes on the end of the brush didn't get dropped under a piece of furniture and you forgot about it. If the problem keeps happening, take the brush and belt back out and carefully turn the machine on to see if it makes the sound. If it doesn't make the sound with the brush out, the problem is with the brush assembly. If it does make the sound, the clutch that turn the brush on and off is damaged and needs to be replaced. You can order a new clutch assembly and replace it without much trouble. They want you to think you can switch between floor and carpet settings all the time but it's really really stressful on that clutch to switch between settings with the motor running. Think about how powerful that motor is. Think about the poor unassuming brush assembly being jerked to life by that powerful motor running at full speed. I've seen that destroy a clutch in about two years. Anyway, it's much better for the life of your dyson to turn the motor off when you switch to carpet mode (when you turn the brushes on). You probably don't have to bother turning off the motor when turning the brushes off, or switching to bare floor mode, because it's not that stressful on the mechanism to just disengage the running motor.
Sep 20, 2009 | Dyson DC14 All floors Bagless Upright...
Riccar 1700 power nozzle wont turn on
Make sure the 'Power brush' switch on the contol panel on the hose is depressed. Check the circuit breaker on the power nozzle; it will either be a button or a breaker that looks like a rocker switch, try to reset it.
Is the power nozzle motor running but the brush just isn't turning? If so you may have a broken belt. Not a likely solution since the belt is a lifetime belt, but still remotely possible.
Apr 23, 2009 | Riccar RC1100 Compact Vacuum
Agitator wont turn
Some of these have a resetable circuit breaker, if it has one, push it. There is a motor on the brush roll which could be bad. There also is an on/off switch, it may have a problem.Also may have a switch where the hose goes into, some models have a actuator for the switch, when the hose is pushed in, it actuates the switch so the brush roll motor turns on and stops when you pull the hose out.
Sep 03, 2008 | Kenmore 31913 Progressive Direct Drive...
Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Jan 26, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vaccum wont work
There is also a reset button on the side at the bottom. Good luck.
Oct 14, 2007 | Vacuums
Kirby G4 Bagged Upright Vacuum Logo
63 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
