Question about Kenmore 24902 Top Load Washer
How do i attach a washer belt to lady kenmore 90 series ultra
Belt is still in tact,
I just don't see any pulley system to attach it to?????
who designed this thing???
  • Kenmore Master
  • 8,220 Answers
Here is a few repair pictures and the MANUAL
Posted on Sep 05, 2009
Lady kenmore washer
Locate contact point under the top section of washer near the lid
Dec 10, 2013 | Washing Machines
Kenmore ultra fabric care ll heavy duty 90 series. Will not drain after washing.
If this machine is new or old sometimes wash items get out of the basin and clog up the pump. This may not be the problem in your case. Let's look at the pump. Is the belt tight? Sometimes you can see into the pump ,is there something visible in the pump preventing it from turning? Is the belt worn to the point that can't turn the pump pulley? With belt off pulley ,can the pulley be turned by hand one way or the other, I mean is it seized?Check these suggestions, and get back to me with how you made out. GOOD LUCK.
Aug 29, 2011 | Kenmore 23822 Top Load Washer
Not spining- water standing can't get water to
If your washer is not spinning ! You first need to drain it. Then underneath your washer you will find your drive system. It will consist of drive belt, drive pulley or pullies and motor. Belt could have come off , if so check the condition before reinstalling, also some times from overloading the belt will spin on the pulley which will make it hot and thanks to the manufacturer the pulley is likely plastic. Parts supply shops best source for belts and possibly pulley though sometimes they want to sale you the whole motor with pulley which you don't need. If so uae internet to find your pulley probably under 10.00 dollars. Hope this helps.
Feb 23, 2010 | Kenmore 23822 Top Load Washer
Kenmore 90 series washer does not drain
Check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 21, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
REMEMBER BELT GOES AROUND IDLER PULLEY AND ATTACHES TO MOTOR SHAFT ,PULL BELT W/ HANDRUN BETWEEN ROLLER, AND PULL BACK AND ATTACH ON MOTOR PULLEY AND THAT ITS
Jan 02, 2009 | Kenmore 64952 Electric Dryer
Kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Sears Kenmore Dryer. Model/stock no. 76691100 belt is broken, and a pulley attached to a spring steel L with a 90 deg bend is unattached from the machine. Joe
RE ATTACH IDLER PULLEY TO GROUNG ONLY 1 WAY TO FIT RUN BELT THROUGHT PULLEY IDLER AND BEND BACK TOWARDS MOTOR TILL IT ATTACHES TO MOTOR THAT ITS
Nov 29, 2008 | Kenmore Dryers
Kenmore 24902 Top Load Washer Logo
270 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
